OT: Cleaning Leather
Bob Hutchins in central Texas
>With apologies aforehand -- Can anyone tell me what might clean a leather handbag? Her Ladyship has a favorite leather purse (given to her by the Princess) that has become soiled around the top zipper area (probably from too much hand cream and lotion), and she has asked me to try to clean it. She has already been over it with a leather cleaner of unknown variety. I doubt that saddle soap will get it clean. Is there any sort of cleaner (alcohol, mineral spirits, turps - yeah, I know, ODOR) that I can get to clean it? I want something that won't remove whatever dye or other coloring agent was originally used on the bag, OR one that will remove everything to an even tone so that it can be re-dyed.
If it matters, the leather is not highly polished. It is relatively supple and has little pimples on it that are probably where hair was in the hide (having NO knowledge about leather, I'm guessing wildly here).
Sure would appreciate any help. This is an opportunity to put on the blue tights and red cape (DO NOT TRY TO IMAGINE THAT SIGHT; IT MIGHT BE DANGEROUS TO YOUR PHYSICAL AND MENTAL HEALTH) and redeem myself (for a change) with HL.
TIA
BobH
Re: OT: Cleaning Leather
Skip in Falls Church
>Hi Bob,
There are some specialty cleaners out there - althugh I don't know of any specifically. If you have an old style shoe repair place around you might take it by and ask them. You might also try calling Tandy and see if they have anything. Their customer service is reputed to be fairly good - at least according to the people I've talked to. There are also some online places you might try - I think one is called Springfield leather - but the link is on my work computer.
This probably won't help but one of the cats peed on my wife's really expensive leather purse (large American Indian style with lots of fringe) and she was about to just toss it out. I figured I couldn't do it any worse so I soaked it down one section at a time with water and pressed out the water using paper towels until they quit changing to a yellow color and then repeated section by section until I'd done the whole thing. (I did this in stages over several days.) I then let it dry and laoded it up with neets foot oil compound and it's pretty much as good as new. It certainly doesn't smell of cat pee. Talk about earning bonus points!
Any way, sorry I can't be more helpful.
Skip
Tony - Memphis
>What about automotive leather cleaners? Also, you might try a shoe repair shop.
Tony
consult a saddle shop, one's recommendation
bill tindall
>I had this problem and found myself in Cody, WY where there is a shop that makes, restores, refurbishes or conserves saddles and the like. They work on saddles, some costing tens of thousand, and seemed to know about these things. Here is what the person recommended to me to clean, restore a very valuable carved leather belt......
If the leather is lacquered, which is common to protect it, remove lacquer with a piece of sheep skin wet with acetone. Gentle strokes so as to not skuff. Then again, using sheepskin wet with a soap they sold there, gently wash the leather (avoid scuffing) and finally rise with water. Presumably any saddle shop would have this or an equivalent soap. It was called BIC 1 and came in a black bottle. They had a second preferred product but it came in a needlessly (to me) large size only that cost a lot.
This part blew my mind. Then reoil with a high quality neatsfoot, or preferred, was olive oil. Small dabs of olive oil are applied and worked into the leather by flexing the leather. Oiling will darken the leather, if that is a problem. By dang I tried this on a brittle leather rifle sling and it softened it back to utility. It took a lot of working the leather to get it resoftened.
Finally overcoat with harness dressing which is a lacquer product. This is padded on with sheeepskin pad. Should be as easy to do as French polish (a little humor here).
One might imagine that this process applied to an antique saddle might cost some serious coins.
They didn't use any sort of waxing of the leather and expecially recommended against it for the carved belt (or saddle) as it would fill the carving.
Find your local shoe repairer. Then run like hell! *LINK*
David Barnett - Venice, Florida
>I've seen so many leather restoration disasters -- especially attempts to clean and spiff antique books. Seems every 'expert' has their pet formula. Problem is, these techniques don't always match the leather, the type of finish and dye, nor myriad other crucialities. Archivists and conservators consider a bewildering collection of factors; the size, density, abrasion, adhesion, and chemistry of the contaminants, particle extrication actions of various detergents, effects of different penetrants, lifting viscosities, and much more (and never stop chanting "pH, pH, pH"). It's hard to imagine a consumer-level product that actually works well and isn't likely to make things worse, but Summit's "Lexol" comes close to perfect, in my somewhat informed opinion. What can I say? We use it on the Gulfstream II.
Lexol-pH leather cleaner information sheet
Re: Try Shampoo, leather is a skin
Dale Lenz-Tahlequah, OK
