We value your privacy.
>Help!! About 2 months ago I bought the Grizzly G0586, 8" Jointer to get all the X-mas stuff done...yea right. It is pre-wired for 220/240V and all I have is 110/120V. When I ordered it the CSR at Grizzly said all I needed to convert it to 120V was to change the switch...well that was two months ago and I just got a notice from Grizzly saying that they do not have the part and cannot estimate how long it will take to get the 120V switch. What options do I have? Is the Grizzly switch my only option or is there another brand of switch I can use? It is a great looking piece of machinery...too bad all I can use it for is as a door stop for now. Help!! Eugene.
>I have two grizzly tools that run on 220. I just wired a new 220 outlet. It is not that hard and your tools will run better on it. Try getting a friend who knows about electricity or hire an electrician. I did it myself including putting the wires into the pannel. I did it for another person and one of the wires touched the nut holding the power comming into the house. That was indeed a near miss. Better to pay and have it done right.
>I should have added that I had an electrician come over to put a 220V switch and bec the main power to the house was on the opposite end of the garage and having to update the breaker box (all breakers are taken) that one 220V switch was going to run me about $900...so I guess I have to make 120V work somehow.
>This particular forum focuses on hand tools, so you may not get the best answers here - a post on the general message board will likely yield more information.
But, since you're here: power tool switches are of several different designs, but, within a design, you can find universal replacements. You may need to dink around with or replace the box in which the switch is mounted, but it'll cost you less than $900.
Look in your Yellow Pages for Electrical Parts or some such, and find a place that deals with contractors but will still sell retail. The best place, but they're wholesale only, is Grainger's; if you've got a friend in the trades, see if s/he's got a Grainger's account. Take all the details on the jointer that you can; maybe even remove the switch and the box it's in and take it with you, so they can see what you've got.
You'll probably need to change over the wiring in the motor, too; the incoming wiring right now is set for 220V. I've never owned a Grizzly tool, but hear good things about their customer service, so you can probably get the information you need to switch it over, but if you're uncertain, again, find a buddy who's comfortable with electricity.
Closing with a hand tools sales pitch: a lot of us on this forum have owned jointers and moved away from them, as we've learned how to use hand planes better. If/when you get to that point, 220V/120V issues melt away.
The only difference between a 120v switch and a 240v switch is that the latter is double pole. That is to say that 240v uses two hot wires (and a ground) and the switch has to break both of them. A 120v circuit uses one hot, one neutral, and a ground and you only need to break the hot.
All you need to do is determine which of your two wires going to the switch will be the hot. Leave that in place. Disconnect the other two wires from the switch and connect them together with a wire nut.
Then make the changes at the motor and with the plug.
Ooops. It dawned on me that your jointer may have a magnetic switch. My previous post regarding switches applies to mechanical switches ONLY. I don't know if Grizzly uses a mechanical switch or a magnetic one. My Bridgewood 8" has a mechanical switch.
If you do need a magnetic switch, you might check with Wilke Machinery. They sell them ala carte and they are probably priced on par with Grizzly.
