Making Drawbore Tools
ThomD
>The drift pin tools in the WWM article aren't available locally, and what I did find was a lot more expensive than the listed 8 piece set in the article. However, none of the sets I found had the 5/32"-3/8" taper over <4" mentioned in the article.
It's probably easier just to make one. Schwarz mentions the 5-32" dimension is a little fat, so the main design issue would be the rate of taper. Does anyone have an idea of the perfect size? I would have thought a 6" taper would be a neater fit, but I don't what it to get jammed, any suggestions?
