A55 Smoothing Plane
Review: Rob Cosman�s Planing DVD�s
Garrett in Victoria
>"Hand Planing and Sharpening"
and
"Rough to Ready"
Rob Cosman is known to most woodworkers, especially those who like hand tools. Many of us have seen him demonstrating planes, saws, and technique at woodshows all over North America, and we�ve gone home convinced by his words and actions that we, too, can do what he does. His demonstrations of how to plane difficult woods are not only inspiring, but unlike a magician, he freely reveals his secrets to success. Not only does he say that his methods are easy, he shows by example that they are simple and straightforward.
Unfortunately, when we try them in our own shops a few days later, they no longer seem quite so simple nor so easy, and the results are not � in my case, anyway � always quite up to Rob�s standard. So what went wrong? The devil is truly in the detail.
A month ago, when I saw Rob at it again, still insisting and proving by action that planing is easy, I soon saw a few small things I�d missed a year earlier. That let me know that I�d probably miss or forget a few more things the next time I tried to emulate his technique. And even though I�d read and kept as references a few articles by other master craftsmen, watching Rob in action and listening to his comments was far more illuminating than reading similar comments and looking at still photographs. So, I bought his DVD�s..
There are some commonalities among the programs. All 5 titles now on offer were shot in Rob�s shop in � I think - eastern Canada. And, the distractingly beautiful view through his windows indicates it either snows all year round, or they were all shot during winter months. He is joined in each video by a sidekick who acts as a conversational partner and helps the dialogue along with quiet questions and comments. While there are some necessary overlaps in content such as the sharpening techniques required by the particular lesson, I found them very much in the nature of helpful reviews that reinforce the key messages in the earlier DVD�s and each adds some new information or tips.
Hand Planing and Sharpening opens with Rob planing gossamer shavings off the face of a piece of highly figured birds-eye maple. Bruce Dennis almost immediately asks, �It looks like a lot of work, wouldn�t you be tempted to take a belt sander to it?� And Rob�s answer is �Yes. But you�ll get the best surface with a hand plane, especially on a piece of wood like this.� He then asks Bruce to compare his planed finish to the results left by a surface planer on the other face of the board. Obviously, no contest. Responding to Bruce�s next question, Rob then presents the four planes he considers are required to do the majority of work in a cabinet shop, and the several options for individual choices within the group. He goes on to examine the various components of the plane, effectively demonstrates why being able to adjust the size of the mouth is important and how various designs make that adjustment difficult or easy, explains why thicker blades are better than thinner ones, the benefits of using higher grade materials in the bodies, and why he prefers planes with mass.
His approach to sharpening will resonate with many woodworkers for its simplicity, speed and effectiveness. After showing how to maintain and use waterstones � no tool guides - he moves to a high speed grinder with a coarse carborundum wheel � not aluminum oxide � with nothing more than a simple solid wood flat tool rest, and explains why he prefers this approach. One of the better tips in this section is how to get the blade parallel to the base of the plane, and he then finishes by showing how body weight shifts make the plane more efficient and effective, and by demonstrating the four different plane types in action.
In Rough to Ready his sidekick is Mark Eaton whom he introduces as a �recognized expert in power tool woodworking�. Mark admires a table Rob made, but asks why anyone would want to make it with hand tools only. Rob explains his rationale for hand versus power, and then launches into the dimensioning and surfacing of a length of rough 4/4 mahogany. He introduces the unique scrub plane which wasn�t covered in the previous video. With its very thick convex blade, it poses a different sharpening challenge, so once again Rob takes us through grinder and waterstone routines, this time showing the different method required by its blade. After cutting a length of mahogany, his first step is to flatten one its faces to lie absolutely flat on his bench.
This process is a good example of one the qualities that make his work perfect: patience, patience, and more patience. It would have been easy for the DVD to drop a few of the test fits and cuts and skip to the end � not to mention making it seem easier and faster - but he persists in getting it right all the while stressing the point about the importance of getting that face absolutely, perfectly flat. Another interesting and useful tip for locating high spots on the surface of the board makes it easier. With that done, the board is flipped so the dead flat face is lying on the bench, and the camera then switches to an overhead view for one of the more dramatic sequences in the series. Rob swiftly and accurately swipes the scrub plane across the grain of the exposed rough face taking deep cuts at an angle while moving from right to left until a completely new surface is exposed. Wow! (This sequence shows why he is built like a mini-linebacker!) The plane tracks are perfect.
A switch to a jointer � not powered - and another brief sharpening review with another new trick added results in a board that�s coming close enough to being surfaced on one face that winding sticks come into play. (Their use is clearly demonstrated with enough information imparted for a viewer to be able to make his own pair.) With the face jointed, a smoother is then used to take whisper thin shavings that give it a lustrous finish. This face now becomes the reference face against which the other 5 edges are finished. Yet another unusual tip is offered as a means of squaring an edge of the board to the reference face.
With one face and one edge now finished, Rob then introduces a shop-made panel gauge. Looking like a marking gauge on steroids, it scores a line along the face adjacent to the remaining rough edge to which one can plane accurately to ensure that both edges are parallel.
The next step is to use a shooting board to square the ends of the board to both the faces and the edges. This stage introduces a specialty plane, the �iron miter�, designed to be operated on its side with the shooting board. For the other end, knowing that few amateurs - or even pros - are likely to own an iron miter, he uses his jointer plane with the shooting board to produce an equally perfect end-grain shaving and square and parallel edge. Clearly, either plane does this job well.
With all 6 sides of the board in parallel and square, Rob then shows the correct method to use a disk marking gauge to score reference lines for thicknessing to a finished dimension. Once again, the scrub plane comes into play to rapidly bring the board close to its finished thickness, again followed by the jointer to level the surface within a hair of the scored lines, and finally the smooth plane to finish the surface off to perfection.
I watched both videos twice before beginning to write this review, and then watched them a third time, stopping and �rewinding� as necessary as I put thoughts into words. The first time through, I found the material was interesting and that it held my attention, was very well structured and delivered, and professionally produced. However, my initial impression of the Hand Planing and Sharpening DVD was that it had seemed rather thin. I was wrong. On second viewing of both DVD\�s, despite thinking I had paid very careful attention the first time through, I was surprised to see and hear lots of �new� material that I had missed the first time around, and it seemed to me that both DVD�s ran longer than I remembered. I was sure, by then, that I had exhausted the content and was ready to make judgments. I was astonished, therefore, that on the third run-through, I again picked up on small but important details that hadn�t yet registered, and I�m sure there are a few more waiting for me when I look at them a fourth time. In fact, these videos ultimately surprise with the richness of their content, but they are quite subtle in presentation. The more a viewer knows, the more he will get out of them.
The experience of multiple viewings led me to realize why, after watching a live demonstration, I was unable to come close to emulating what I had seen. While extremely useful and entertaining, it�s simply impossible to note, absorb, and retain even most of the information being presented in a single pass at a live demo. On the other hand, the ability to have that demonstrator in your own shop as often as you want, and to be able to focus on specific aspects of the presentation as many times as necessary, does make it possible to improve and possibly even reach the perfection of a demonstrator as able as Rob Cosman.
Cheers, Garrett
Re: Review: Rob Cosman�s Planing DVD�s
Interesting...
Scott Burr in Ben Lomond,CA
>Glad you liked them Garrett. I returned mine to LN because I found little or no new information out of them. I thought they were quite bland in presention (i.e. boring) when compared to others instructional works. I still prefer the late Jim Kingshott's videos from all others I've seen.
Thanks for your review.
Re: Interesting...
Garrett in Victoria
>Hi Scott
Maybe you, too, should have looked at them a second and third time.
(Just kidding.)
I'm slowly moving back to hand tools after a long hiatus, so they provided a very useful core of information for me.
Cheers, Garrett
Arw01
>Garrett, you should take holiday this July and head to Calgary for a week of in class time with Rob..
Went last summer and I am thinking of taking the same class again!
Alan
Re: Interesting...
Brent Smith
>Of the 3 sets of videos (Cosman, Kingshott, Charlesworth) I've seen on handplanes the Cosman videos are, to me, the most useful in the real world. Kingshot and Charlesworth are great craftsmen and teachers, but their videos delve into the why as much or more than the how. In my opinion, their videos are great follow ups to Cosman's lets get it done style. I believe a person should learn the basics of how to do something before he starts looking for the refinements of the procedure. Rob Cosman seems more interested in getting the viewer up and running, while Kingshot and Charlesworth want to explain some of the more subtle things involved in hand planing.
All in all, they are all great videos for learning the art of the handplane.
Brent
>Many years ago, back when I thought a DeWalt radial arm saw was really, really kewl, and before I decided I would rather design and build things in wood instead of from ones and zeroes, a wise man told me,
"You have to understand most of the answer before you can ask the question."
They say a picture is worth a thousand words. I guess a video is worth a thousand pictures. (Maybe, worth a thousand times the number of frames from which it is built).
Still, much is lost in the one stream of audio and video in the DVD. The rewind button is really helpful, but most of the time actually being there, and asking the wizard to show you again, makes all the difference.
No matter how many times you replay Casa Blanca, you're never going to hear Bogie say,
"Play it again, Sam."
Dan CLermont in Burnaby
>I think that says allot. Have never taken one of Rob's courses but I do hear they are allot of students who go back year after year.
Cheers
Dan Clermont
>Hi Garrett,
Totally agree with you. I have not seen any of CHarlesworth's, Klausz, or any instructional videos but do find I need to watch Rob's videos over and over again to take it all in.
My fave is the drawer making DVD followed by the dovetail DVD> I have never seen ROugh to Ready
Maybe we West Coasters can convince him to come out for a week and teach a course
Cheers
Dan Clermont
Cheers
Dan CLermont
John Clifford
>Amen Brother. And a good bit of trivia that a lot of people don't know about with regard to Casa Blanca. Probably one of the most famous misquotes of all time.
LAX terminal and Casa Blanca
Martin from Granbury, TX
>I get out to LAX once in a while in the wee hours of the morning. Directly east of the FedEx ramp, on the northeast side of the airport, is the original terminal for LAX. It was once the passenger terminal for the entire airport, and this is the airport building that is seen (at the end, I think) of Casa Blanca. An old Captain pointed it out, and it matches the building in the movie perfectly. Hard to believe it is still standing after all these years. Hard to believe that the pax building for LAX was ever so small.
Martin, remove "5" for correct email.
Re: Interesting...
paul womack
I am in no position to compare, since I only own the Kingshott bench plane video.
It's pretty good, but I do find his strong implication that if you don't own an infill panel plane and jointer, you can't make wood flat or straight a little extreme!
And some of the statements he makes in the early plane tuning sequence are horrible.
His anology (with the staack of paper) in defence of low edge bevels is simply not applicable in a bevel down plane.
And he repeats the old (and missively discredited) theory of cap-iron (AKA chip breaker) action.
But for overall planing technique, the video is great ... and his accent is pleasing :-)
BugBear
Re: the field?
paul womack
>How many "planing" DVD/videos are out there now?
Kingshott
Cosman
Charleworth
Rodriguez
Patrick Leach
Any others?
BugBear
re
glh
>These don't qualify as plane-only videos, but Frank Klausz has a video on Hand Tools and one on Finishing. In both videos he has some discussion and illustration of planes--more in the Hand Tools video than in the Finishing.
Stephen in Ottawa
>I too agree with you, Garrett. The handplaning and sharpening video was one of my first Rob Cosman videos. I rewatch it regularly and each time I seem to learn something new, even though I initially thought it was very basic. Your observation that the more one knows, the more one learns from Rob is very accurate. I seem to pick up more tips from him each time I watch his videos. I once personally spoke to him about weight transfer when planing and it has helped me remarkably. I only wish I could take the time off to attend one of his classes in Toronto.
I have four Kingshott videos and like them all. I think he and Rob have a similar approach to woodworking, they both are very patient and precise. I think the Rob Cosman and Kingshott videos complement each other.
Cheeers,
- Stephen
Re: Interesting...
Bill Collier
>OK, I'll complete the trifecta and say that for me the Charlesworth series is the most useful, and pretty much for the reasons already stated. The Kingschott and Cosman videos are excellent and cover the process of planing in a general way, whereas the Charleworth video is presenting more of a process improvement that I find very practical and easy to apply. I think that to a certain extent comparing the Kingsschott and Cosman videos to Charlesworth's is not quite but almost comparing apples to oranges. The first two are presenting the topic to someone who wants to see the basics where Charlesworth's seems to be oriented to someone who may already know how to use a plane but wants to learn his method for working efficiently with the plane.
Why?
bill tindall
>"high speed grinder with a coarse carborundum wheel "
did he offer any explanation for this unusual choice of abrasive?
Here's the Explanation
Garrett in Victoria
>Hi Bill
He doesn't make a big deal of it, but says, "People tend to burn their tools because they use too fine a stone. I like a real coarse stone, 36 grit, whatever..."
BTW, he also says "It's not necessary to spend a lot of money on a grinder." He leads by example, because I looked closely and his is a Craftsman!
Cheers, Garrett
Re: the field?
ThomD
>The most important lesson I learned about planing was in the Krenov video. It covers planning as well as making the planes.
There are a number of japanese videos, but I don't know if there is one on planes alone.
Re: Review: Do it yourself
ThomD
>Seminars are great, and inspirational. They can be a great woodworking experience for those who go. And that itself can be a legitimate objective.
If you want to get better, offer to deliver a seminar. If you don't practice and ramp up your game, you end up looking an idiot. It is surprising how much just a little concentrated practice will raise your game. I would say I couldn't cut dovetails convincingly until I offered to do it as a 6 hour demonstration in a classroom setting. I was convincing, when the time came. Showed four different methods, including the crowd pleasing Franz Klaus which I had to learn for the event.
thanks, but
bill tindall
>to offer a second opinion. "People tend to burn their tools because they use too fine a stone." The real reason for tool burning is that the dull particles are ploughing (making heat) instead of cutting (where the heat is largely removed by the chip). Proper wheel bond and grit structure prevent burning. I don't get burning with a 100 grit wheel running 3600 rpm. Mine too is a Craftsman grinder but a premium wheel.
