Follow up on LV BUS and tear-outs (long)
Felix B.
>Last weekend I was able to spent more time with my LV BUS. The original discussion was about the tear-out I was getting on cherry.
As Dan Clermont recommended, I sharpened the blades. I use 800 & 4000 water stones. I don't do it free hand, I use Vise-Type Honing Guide that I bought long time ago for $9 or so.
I closed the mouth as much as possible and tried again with sharp blades (both 38� and 50�). I was beautiful getting super thin, see-through shavings, but I was still getting tear-outs. I looked closer at the mouth opening and I noticed that the mouth was not completely parallel to the edge of the blade. Not that much but still noticeable (maybe 0.005"-0.007" difference)...
Ok, I removed the blade and checked it with the Starret combination square. The edge of the blade was a little skewed! I picked up my honing guide and noticed that there is NO WAY to insure that the cutting edge would be true to the long side of the blade... I suspected this long time ago but never looked into this possibility.
Another thing I did was to check how flat is the soul of the plane. Using 12" Starret combination square, I noticed that the metal rule was touching the soul in two spots: at the handle base and at the front. Since I am using Starret, I left little doubt that the steel rule of my Starret is out of wack. Don't get me wrong, the curve was not big at all, maybe 0.005"-0.007", but it was noticeable against the light.
I am sure if I called the LV, explained my concern and ask for exchange, it would be done easily. It was a weekend and I did not feel like waiting for another two weeks... I did not get discouraged. I pulled out a piece of marble that I use to flatten water stones and robbed the soul on 220 and then 400 grit paper. Checked again - perfectly flat...
After I did that, the plane performed even better, but very small tear-outs were still there. At this point I have very little faith that a slightly-out of square blade is a true cause of the tear outs.
I am wide open to other ideas and possibilities.
Or maybe I am being too particular? But when I hear someone says "no tear-outs", that's how I see it - no tear-outs ... It's obvious that the "experience" is a big contributor to successful planing, which may be the true cause of my tear-outs :~)
Cheers,
Felix
