Edge Jointing by hand - how to
Paul99
>Can anyone point me in the direction of learning how to joint an edge of a s2s board by hand if you don't have a jointer?
Thanks,
Paul M.
Paul99
Thanks,
Paul M.
Re: Edge Jointing by hand - how to
George Makowski
>Paul, Search this board for discussions on jointing. There have been a couple recently. Most general hand tool woodworking books have instructions.
In general, there are two basic methods, each of which have their adherents. One is to plane each edge straight independently using a square and straight edge to check your work and then glue. The second is to clamp both boards together either face to face or back to back and plane them straight and square together. Method #2 is self compensating for slight errors in planing square. Neither method forgives not planing straight. In either method you may check your work by holding the boards together against the light to find any errors.
Good jointing!
George in AL
More info needed
Derek Cohen (in Perth Australia)
>Paul
How long are the boards, what is your longest handplane, and how much experience have you using these?
Re: More info needed
Paul99
>I have an old 12" jointer that I can restore. I looking to do some face frames so no longer than 3'
How do I search the post here? When I sue the search feature it only searches articles not posts?
Thanks.
ThomD
>Not quite sure what you would "joint" in that situation. The term applies mostly to preparing the edges of boards for assembly into wider elements like table tops. In making face frames, you presumably want to diemension your stock, and possibly shoot the ends so they can be neatly joined together with whatever joints you have in mind.
Wrong search feature ;-)
Dan Donaldson
>To search the posts, use the search link at the top of the messageboard. The one you used is for the articles/shop shots etc.
Well Paul... *LINK*
Scott Burr in Ben Lomond,CA
>A 12" planes isin't considered a jointing plane (unless the stock is short) Jointers are generally 20+ inches or more. You could make a shooting board so you could use your plane to get a nice stright edge on them, or go get yourself a nice long jointer.
Here a link to the hand tool archive...
Good luck!
Hand tool archives
Paul99
>Thom,
Sorry. I'm new to WW'ing. What is the best way to dimension the stock?
There are libraries, too
>Learning the particular skill about which you're asking may be better started with a book rather than the internet. Check your local library for a book called "The Hand Plane Book," or buy a book called "Planecraft" from your friendly local or online Woodcraft store (about $10, and a bargain).
Then practice. Pine and poplar are both good woods for practicing on.
ThomD
>1) By hand, you plane the most stable side flat first. analyze this surface, and if there are some lopsided mountain ranges, adjust them specifically. Then work from the middle out. If you don't know how to plane flat, that is another subject...
2) Once you have a flat side, joint one edge to 90 degrees, work from the middle out, do not try to take picture book swipes the full length, at first. Concentrate on getting the edge planar. Check it to see if you twisted it, that is usually a stance and body mechanics issue.
Another flaw is cutting low the entry and exit, this is the result of not pulling the plane on and pushing it off; but pushing it on and pulling it off. It is also exaggerated by not working from the middle out.
If it is off angle there are many ways to deal with that from adjusting the plane iron for a few strokes; to just trying to correct by getting it right this time; to trying to put the plane more on the high side; to cutting in a rabbet that changes the slope, and then planing the tracks away. I once had a list of about ten things you can do. Find something that works for you.
3&4) Once you have two side, you just lay the others out with marking gauges, and hew, saw, or plane to those lines.
