Bedeviling questions
Skip in Falls Church
>The present thread on chair devils is getting buried - but then I have some new questions about them any way. I'm presently working on a couple of new ones with a larger radius. I'm trying to incorporate some of the lessons that I learned from the first two along with what I have learned here and from the latest PWW.
So, here goes:
It looks to me that the few pictures I've seen of older chair devils the opening and the blade are not exact semicircles - but more of 1/3 of a circle with the edges of the blade "buried" in the body. Burying the edges makes sense to me as it would prevent them digging into the work - something I noticed mine would do if I started on a piece too wide for the devil. It also seems to me that making it slightly less than a full semicircle would make sense as well.
In PWW the author beveled the *back* of the blade at 30 degrees but didn't put a hook on it - I did mine at 90 degrees and also put no hook on it. I *thought* I'd seen here that 90 degrees should work. And it does seem to work on the ones I made. Is there any advantage in beveling the blade? Putting a hook on it? Thoughts any one?
I'm lowering the center of gravity on these new ones because that seems to make sense along with using a thicker clamping block to allow a larger throat. I'm also jettisoning the carving - looks nice, but takes up space that would raise the center of gravity. However, I'm sticking with Jatoba and apple as the two woods because I like the way they look together. I'm sticking with the same handle design as well except I'm making them slightly longer. I don't have a lathe so turning handles like they did in PWW is definitely out. I'm also dumping the brass wear plates - it just seems like overkill to me. On the previous ones I made I did not bevel the openings as they did in PWW - that detail wasn't obvious in anything I had seen - so I'm doing that on the new ones. It makes sense to me as it allows the blade better support by keeping the edge closer to the body.
I took a number of pictures as I made the previous ones with thoughts of doing an article, however, I've been pretty busy lately and haven't gotten around to it. If anyone would like I'll do that incorporating the information I've learned since. I do have to say that chair devils are really easy to make. Far easier than spokeshaves IMO. I don't see that there is any reason that anyone that wants one shouldn't just make one or more.
Skip
