Convex Spokeshaves?
Convex Spokeshaves?
Convex Spokeshaves?
Denny
>I'm thinking about using a convex spokeshave for finishing the undersides of the ends of a tabletop (an excuse to buy a new tool). The only convex shaves I've been able to find are a cheap one by Kunz and an expensive Clifton model. (I'm not looking for a round bottom shave with a straight edge blade, the convex spokeshave has a curved blade.) I'd like to know if anyone has any experiece, good or bad, with either of these tools, or is there some other tool I should be considering?
Thanks,
Denny
Re: Convex Spokeshaves?
Darrell in Oakville
Re: Convex Spokeshaves? *LINK*
Darrell in Oakville
>I'm not sure if you mean round bottom shave when you say convex, or do you mean something like a travisher? Have you looked at Lee Valley's offerings? I have their low-angle shave, the wooden shave kit and the concave shave. Use'em all the time.
Darrell
Wood Hoarder, Blade Sharpener, and Occasional Tool User
Lee Valley Spokeshaves
>St. James Bay Toolworks makes and sells small convex bottom shaves, and also violin maker's planes, with even tighter radii. Other alternatives include the Stanley 100 1/2 Model Maker's Plane, which you would have to hunt down on the old tool market, its Woodcraft reproduction, in bronze, and the new Lie-Nielsen version. Note that both the longitudinal and latitudinal radii of the L-N are significantly larger than the other 100 1/2 models.
In the "good old days", they realized that no one was going to look at the bottom surfaces that I think you are wanting to be shaping, only at the front surfaces, and at the edge of the bottom profile. Therefore, the profiles were usually defined with carving gouges, and the bottoms rough cut with a turning saw and relieved with gouges and other rough tools.
paul womack
Since this is a long straight cut, I'd recommend a moulding plane; in this case a generic moulding plane, called a "round" (which cuts a hollow).
Alternatively, remove as much waste as possible with a straight bladed plane (e.g. #5), then work the hollow with gouges and/or a scratch stock .
BugBear
Denny
>Darrell,
Actually, I am looking for something closer to a travisher. I have a LV round bottom shave, but I'm trying to end up with a long concave edge. I think some of the suggestions below are probably just what I need...
Thanks,
Denny
Denny
>William,
I think your suggestions of St. James Bay Toolworks or L-N might be just right, especially after seeing some of the prices for the old Stanley versions. I'd like the bottom surfaces to be refined, especially because I'd like to be able to use a similar approach on taller pieces with overhanging tops, where they would be very visible.
Thanks,
Denny
Denny
>BugBear,
I might give it a try with a round, any recommendations on where best to get one (other than ebay?)
I already tried something close to your other idea. I beveled the edge of the wood and then tried to carve out the hollow with a curved-edge hand scraper. It worked great when I tried it along the grain, but I couldn't control the tearout when I used it cross grain.
Thanks,
Denny
paul womack
If you're into geometry and shop made tools, you might try a skew blade scratch stock with an elliptical cutter!
BugBear
