how to fit this......
bill tindall
>I need to shorten the wood part 1" and refit the brass part, nicely. How to?
Re: how to fit this......
Bob Fawcett
>From your photo it appears that once you have cut 1" off the stock the brass will be longer than the wood from top to bottom. I think you will have to reshape the end of the brass at least. You may also have to reshape some of the wood. Stocks usually have taper in more than one direction. My guess is you will have to reshape part of the stock and refinish it. Maybe someone else has a better idea.
You may want to post this on a gun list and see if they have a better idea. I used to follow the Airgun forum and there were lots of helpful people there like WC.
Try this link.
http://www.network54.com/Forum/79537/
There used to be a couple of people on the list that built stocks.
WoodburnBob
>Bill, looks like a challenge, but as you break down the task into little steps, what part of the process has you stumped?
Here's me thinking to myself:
"After removing the brass piece, I'd want to cut off the 1" perfectly so I wouldn't have to mess around. Looking at the form I see a big radius, a small radius and a straight. For the big radius I'd think about using a powered router on a circle attachment. But I'll have to have a sacrifice clamping block where the bit comes out to prevent tearout. I'd block and clamp the gun stock perfectly and really make a big production out of getting rigidity and alignment to some flat solid surface. I'd use a stick with a nail in both ends to find the approximate center of a circle to get the big radius. Then I'd set up the router with a circle turning attachment of some sort. Then fuss with alignments using a piece of paper between the bit and the butt to check. Then increase the circle turning radius 1". Then cross my fingers. The little radius and the straight, I'd find a gouge and use a little back saw.
Another alternative would be to search my friends for someone with a tracer mill. This is impractical but would justify lots of procrastination. That's really the way to go about this...put it off."
All stupid thoughts, probably, but at a bargain price.
Bob
Fred Krow
>Most of the Gunsmiths who shorten a factory stock will use a belt sander with 1" X 42" long format. They will use tape on the stock to help prevent marks on the finished wood while carefully sanding the metal to final dimensions. You could also use files on the brass after inletting the matching curves of the butt plate to the stock.
Stock inletting black is available from Brownells
http://www.brownells.com/aspx/ns/home/default.aspx
The product description even specifies curved butt plates as a common application.
http://www.brownells.com/aspx/NS/store/ProductDetail.aspx?p=7599&title=INLETTING+BLACK+%26+GOLD
Good luck,
Regards,
Fred Krow
>Bill, I would remove the butt plate and scribe the outline of the buttstock exactly 1" (or whatever distance you want) further forward on the stock. Using the existing stock profile for a guide, you should get it pretty accurate. Scribe lightly on initial passes and eventually (3 or 4 passes) you'll have a good scribe. If you carry the scribe all around the stock you will have a good guide to prevent you from sawing crooked...in the next step.
You can now choose your weapon of choice to remove the unwanted wood. I would use a coping saw and saw to within less than 1/16" to my scribe. I would then fit the butt plate using some type of blackening agent rubbed on the brass butt plate that will leave a smudge on the wood telling me where to remove wood using a sharp chisel(s). Remember, you will be sinking the brass plate into the wood in 2 directions, forward and down. The key to success here is patience and ahh, did I mention it, a sharp!! chisel. Have fun.
this is the part that has me stumped
bill tindall
>"scribe the outline of the buttstock exactly 1" (or whatever distance you want) further forward on the stock."
I can't use the butt plate as a guide because of the profile of the stock across its thickness will not enable the butt plate to lay against the wood. Maybe use dividers? I presumed the rest would be brute force cutting and fitting but thought I would ask if there was a simpler way and there apparently isn't.
I will like this rifle as soon as I am able to reach the trigger (It's a Hawkin and I don't want to mess it up.)
Re: this is the part that has me stumped
>Yes, dividers will work. The profile of the butt will serve as the template to guide one leg while the other scratches the finish. Remember, the scribed line is just to make sure you cut almost all the wast off.
I wouldn't consider it brute force. More like brute finesse. It's really very rewarding work....watching the brass casting meld with the wood. I've done quite a few of these and after botching the first one or two I settled down, learned to let it happen, and voila...it got to be fun. A firm rule I have is to force myself to leave the work if I sense myself becoming hurried, frustrated, etc.
The butt plate will be slightly larger than the wood when you're done. If you're careful, you can place tape around the buttstock to protect the finish and file the brass down to the tape. The final passes should be with 100 grit emory wrapped around a file.
Derek Cohen (in Perth Australia)
>I have not done this before, however my first thought would be to make a template out of paper. This can be wrapped around the stock, and basically adjusted until you have the ideal fit. Then mark it and cut it out.
Dan Clermont in Burnaby
>What about tracing it on laminate, plastic or a thin piece of wood and then trace it? Then bend the traced pattern on the stock
Dan C
why this doesn't work (I think)
bill tindall
>the stock is profiled in cross section. So, the butt plate shape needs to be projected onto the stock. Any bending of a pattern around the stock will alter the shape (I think). Because the stock tapers lengthwise too, I can't wrap something, trace the current profile and then wrap 1" higher.
I have already mowed off the top horn from this butt plate (damn thing caught in my jacket every time I raised the rifle) so I am not at all reluctant to mow off more brass to get the butt plate to fit the altered stock.
I am trying to keep in perspective that this is a tool for killing deer and not get too carried away making this an extensive woodworking project, but then there is that pride in workmanship consideration that seems to lengthen my most utilitarian projects.
In any case thanks to all for the advise.
further question
bill tindall
>am I to understand that a chisel is the preferred fitting tool? I have never had much luck filing/ rasping this kind ot task and keeping the object from being rounded a bit. I want things to happen slowly so a coping saw will be the saw of choice.
Now if I can just get something young, tender and stupid to wander by. I used to shoot these things years ago at the Fort Ticonderoga matches and I still seem to remember a little of the techniques.
Re: further question
>Tools I would use: Dividers, coping saw, chisels, files, sandpaper, emory paper.
