Which technique would you choose?
Steve Kubien
Steve Kubien
>Afternoon everybody,
I have needed to make a whole pile of 1/4" x 1/4" sticks (pine, actually). I got lucky and ran into a bunch of 1/4" x 6" stock left from a milling jump at my lumber yard so I got no waste getting down to thickness. To get the width, I tried to use my t*abl*s*w but without a zero-clearance plate, it was dicey. Bits of wood being thrown around the shop killed the idea entirely so here is what I did...
I picked up a Japanese-style mortise gauge with knife-like blades, set the projection to get halfway through the plank and went at it from both sides. This left me with 3 good sides and one edge that looked like a peaked roof. I ran that side over my inverted Knight smoother until the pieces were truly square in profile.
So, my question is this...Is there another neander way to do this sort of thing? Firmly holding on to such small stock has caused major cramping in my hands and pins-and-needles in my fingers (really bad right now because I'm participating in a martial-arts demonstration tomorrow). If I only had to do a few pieces it would be no problem but I had to get through over 80 of these things and will likely need to do so again. Is there a better way?
Thanks for your help,
Steve kubien
Ajax, Ontaro
Re: Which technique would you choose?
This could work...maybe...
Scott Burr in Ben Lomond,CA
>Do you have a No. 45 or any other plane that comes with a slitter?
You could possibly attack the board from both sides cutting towards the center. Then split them like chopsticks come apart, then clean up the split sides with your smoother.
Otherwise I'd probably be investing in a zero clearance insert :^(
Warren in Lancaster, PA
>Steve, I like to clamp the stock to the edge of the bench when I do slitting like this. Sometimes I work part way through from both edges when the stock has gotten narrow from having pieces removed. True up the blank after removing each stick.
You don't say how long your sticks must be; I would think you could plane up to 16" or so against a bench stop without whipping. Take a light cut. For longer stuff I find it less tiring to pull it across a plane in the vise than to push. I usually pull with my right hand and hold it to the plane with my left.
Steve Kubien
Steve Kubien
>Now why didn't I think to pull the stock through the smoother rather than push it? That ought to be a lot less stressful on the fingers and hands. Thanks.
Steve Kubien
Steve Kubien
Nope. *LINK*
Steve Kubien
>Hi Scott,
I haven't got a 45 or anything like it. I'm not too familiar with the slitting blade you mention but the mortise gauge sounds like it works in a similar manner. Check out the link below to see the gauge I bought (I really like the gauge BTW). As for the zero clearance insert... I am really trying to avoid the tablesaw, especially with such small pieces. Makes me nervous and that a bad combination with power tools.
Thanks for the help,
Steve Kubien
Mortise gauge
>In my opinion 1/4" wide stock is too thick to slit efficiently. There is a small chance that I don't know what I'm talking about, but I alwys thought a slitter's main purpose was to make thin strips about the thickness of veneer. If I had 80 of these strips to make I would rip them on the neanderbuddy (b*nds*w) and then use a stop on the bench to push them against as I plane the edges. Planing a lot of long thin stuff is easier to do by holding the plane than it is to fix the plane and pull the stock across, because thin stock bends. If you put it on top of a solid surface held in place with a simple stop it is very easy to get it square and smooth.
Just buy a zero-clearance insert . . .
ydb1md
Re: Just buy a zero-clearance insert . . .
Frank D. in Montreal
>I agree, for production work why not use what was invented for mass production--machines. I use the Grripper for thin pieces and it works incredibly well, otherwise you can make a "pizza slice" push stick, a piece of wood shaped like a slice of pizza that holds down the thin piece between the blade and the fence. You just have to cut along the bottom edge of the pizza slice and stop short of the end under your hand, so you have a stop to push the wood through the cut (so the machined piece doesn't slip). With a TS you won't have much cleaning up to do with a plane (a lot less than if you cut it with a bandsaw).
Hope that's clear; sorry to be pushing power tools on the hand tool side of the board.
Frank
>I assume most of the pain is occuring during the flattening, not during the slitting. If you are also experiencing pain while slitting, a #45 would be worth the search. I think you would find a sticking board useful. Several good examples are provided by a google search, but several totally OT references as well.
http://www.google.com/search?num=20&hl=en&lr=&ie=ISO-8859-1&safe=off&q=%22sticking+board%22
Probably something not as "complicated" as the ones used for muntins, just a board with a 1/4" high fence and a stop made from a screw.
If you are trimming very short sticks, pushing them over an inverted jointer will work, but a push stick to hold the stick would be very helpful, kind of like an upside down sticking board with a handle.
>Actually my tool of choice for this type of operation would be a bandsaw. I think 6" is too narrow to saw by hand, and too dangerous on a tablesaw, especially if you want to use the whole width. A 1/4" thickness is too whippy for a framesaw or ripsaw. So a 'lectric bandsaw it would be for me. Since it is soft pine, I would just set my fence a tad over 1/4" away from the blade and feed it all in. Then clean it up with a sharp block plane (one hand on the plane, one hand holding the thin sections - alternatively, clean up as you go along).
Yet another way (just for the record)...
David Barnett - Venice, Florida
>...used by plank-on-frame scratch modelers to make scale timber/stringers, is to handsaw or bandsaw slightly oversized strips which they mallet through a drawplate. If you need special sizes or don't have a drawplate (the made in India "Monopoly" brand is super cheap for a 5.5mm to very tiny 30-hole square plate -- about 7 dollars, I think), drill progressively smaller holes* in a metal plate (doesn't have to be steel), then file to square corners in one direction only at a very slight bevel, if any, leaving any burs that develop, then whack your strips through the opening and you'll have a bunch of equally sized sticks. Works okay on softwoods but hardwoods are better. Bamboo chopsticks make superb trenails.
*You can punch or chisel square holes, too, of course.
Re: Jig it
Tom Price
>Use your slitting technique and then put a jig together with a piece of MDF. Gang several pieces side by side with a stop piece and support pieces on the sides to keep the row of sticks from toppling over sideways and plane them together.
Or, create a single slot to hold one piece and plane each separately, similar in principle to the jig that bamboo rod makers use to taper sections of bamboo for their rods.
- Tom
Ron Smith
>Steve . . . . Perhaps use the table saw AND your new Cutting Guage.
Use the Table Saw to make initial cuts, but avoid the flying sticks by making the cut only partially thru . . . leave maybe a 1/16 or less of stock to hold everything together. Separate the sticks by use of the Cutting Guage, or a sharp knife. Should be quick, easy, and require little, or no final planing.
Or did I misunderstand the question?
Good luck . . .
Steve Kubien
Thanks for the opinions
Steve Kubien
>There's a lot of good stuff in here. Thanks a bunch. I think a jig/sticking board will be the way to go...next time. BTW, I really like using the cutting gauge. Far more relaxing than the tablesaw and I end up with virtually zero waste. Oh yeah, did I mention I am trying to avoid my tablesaw as I want to justify getting rid of it through lack of use? Still kinda reluctant though.
Thanks again for everything.
Steve Kubien
Ajax, Ontario
I would (have)....
bill tindall
>made a zero clearance insert from a piece of 1/2" anything and four set screws (I have even use sawed -off drywall screws in a pince). (I have inserts made from poplar, plywood, polyethylene, bakalite, what ever was at hand when the need arose) Then I would use a thin kerf 7 or 8" blade, 40 tooth. The blades that go on "skill" saws work fine. Though I got a defective 8 1/4" DeWalt blade recently that I intended to evaluate for such purposes. (see post on other side describing). I saw 1/8" stuff with this arrangement and it goes well.
It would make me nervous too...
>I hate messing with small pieces of wood and screaming finger eaters also. I wouldn't even atempt it myself. Ya got a band saw? That would make it somewhat safer...
I have a marking a lot like that one, but mine is a Japanese one with 2 blades. I like it a lot also.
Good luck in witchever path you take.
Steve Kubien
Re: It would make me nervous too...
Steve Kubien
>Is you knife similar to what folks use to cut sections destined to have inalys? Kinda like a pair of tweezers but with knives instead of points?
Steve Kubien
P.S. I tried the bandsaw but found I was a lot more accurate with the gauge. I suppose I could mark deep with the gauge and finish the cuts with the scrollsaw? The deep marks would help act as a guide. I'm very comfortable with my scrollsaw (love it actually).
Mines looks like this...
Scott Burr in Ben Lomond CA
>It's not like the one your describing. It looks like this:
It's a nice gauge BTW. Glad to hear you found a safer work around.
Ripping small Strips
Mike Swindell
>I made over 200 3/8x3/8x4 strips with my table saw from Lignum Vitae, last year for band saw blocks. I had a ZCI and a shoe to push the blocks thru with a rip blade. No problems whatsoever. My shoe was made from 1/2 baltic birch and I just ran the first strip thru and from there on out the size was perfect.
ydb1md
>Good point Derek. I've only recently begun to explore my bandsaw's many uses. I haven't used it enough that it instantly comes to mind when deciding on a tool to use in a particular circumstance.
Adam Cherubini style
ydb1md
>Being that the stock is short (6") you could always use a hatchet or a froe, since pine is soft and straight grained. Then, clean up the edges w/ a block plane.
