REAL MILK PAINT
bowl carving with adze
George D. Huron
>I am thinking of creating a bowl carving class for the school. Any one have experience with an adze? Any preferred adze supplier? Kestrel vs Swedish styles.
Re: bowl carving with adze
Kevin Adams
>Hi George--
I've used both and prefer the Kestrel adzes. I have a couple of them and will be picking up a third (a straight one) sometime in the near future. If you don't know, he is shutting down his business next spring, so if you're interested, you should order soon.
The Kestrels are very light and the geometry is great so they don't tend to "stick" in the wood. The Swedish adzes are also very well made, but they are heavier and tend to "power" through the wood. Either one will work fine, it's just a matter of what feels best to you. If you go with Kestrel, you may want to look at his crooked knives, too. I find these to be invaluable in working things out after adzing. Kestrel used to offer a video that showed how their products worked, etc. That may be a great way to check them out before you buy, although I know he'll take an adze back if you just don't like it. Greg is a great guy.
Please let me know if you have any other questions.
Kevin Adams
George Makowski
>George, I did a fair amount of carving of bowl shapes with an adze at one time. I found it is one of those vastly underrated woodworking tools like the hatchet or axe (See Adam Cherubini in PW #151 and various discussions in Roy Underhill's print and video material). Material removal is fast and can be quite accurate.
I got the best efficiency working slightly green wood, leaving the shape somewhat over thickeness, allowing it to season, and then carving to the final dimensions I wanted.
The only stricture when working hollowed out shapes is that the chips have to have somewhere to go. That means that it is best to start with a small divot in the middle of the form and then carve towards it from all directions.
For inside forms, you will want an adze that is curved in both dimensions to clear the tool itself away from the wood behind the cutting edge.
Good adzing!
George in AL
George D. Huron
>I purchased a medium sized swedish styled adze to learn with. I will keep you guys appraised on the process. I hope that I can put together a bowl class.
Bowl carving gouges
Larry Gelder
>What size/sweep gouges do you use to carve out the bowl after adze work is finished?
