Flattening a monster piece of mahogany
Gary Miller
>Got lucky today.
Bought a 16+" wide, 2' thick, 72" long piece of honduran mahogany (at $4.35/bd ft!). Wonderful color--I know there is a hall table lurking in this piece. Also bought some other 8/4 mahogany that looks like it came from the same tree--color match is excellent, so I'll have plenty of stock for the frame.
The down side is that there is a mean twist in the wide board.
Got good use from my #40, #5.5, #8, and winding sticks. I flattened the non-face side today (about 1.5 hours work). Thicknessing and flattening the face side will be alot more work--but what great fun on a beautiful, fall day. Sore arms, shavings everywhere and the sweet smell of mahogany. It was a good day.
God I love handtool work!
Gary
Re: Flattening a monster piece of mahogany
Scrubbing will give you Popeye arms
Jim Reed@Tallahassee
>sweat in your eyes, and a song in your heart.
Just do it in the winter with the heat off ;-)
Dan Donaldson
Bob Doyle
>Gary,
Unless the hall stand will be using boards the near entire length and width of your boards, cutting to rough length and width first may save you a lot of planing as the twist and cup will be reduced in the smaller pieces. There was a great article about dimensioning lumber that Gary Rogowski did for Fine Woodworking a while back that, even though he was using power tools, it still holds true for manual operations (rough rip & crosscut then face jointing, edge jointing, thicknessing and final dimensioning to width and length)
Stephen in Ottawa
>Gary,
I'd advise against flattening the entire board as one piece, as someone else has already suggested. Rough cut your pieces first. You'll have *much* less flattening to do and waste less of the thickness of your wood.
- Stephen
Good suggestions--thanks
Gary Miller
>The table will probably be only 15" x 60" max, so I'm flattening 12" of the main twist! Not too bright sometimes.
Gary
