Mortising in general
Gerry Mayberry
>I have seen information on mortising by hand and by machine. I have an early small Delta mortiser and use Forest City bits. The mortises are accurate dimension-wise but contain a series of arcs cut by the drill bit outside of the square chisel. They aren't deep but my instincts tell me that a smooth mortise side wall, ie, from a plunge router, would be stronger. Thinking of the old guys using mortising chisels, however, means that the mortise sides were not smooth either and their furniture, often pegged, is still together. This may be a tempest in a teapot given today's adhesives, etc. What is the prevailing thinking on the strength of mortise/tenon construction as described above(with somewhat uneven walls). I bought Forest City bits thinking a better match of drill bit and chisel would solve this problem but I found no difference. In thinking more about the mechanics of cutting a mortise with today's mortise chisels, it is likely that the bit must extend beyond the square chisel slightly, and slightly is the operative word.
