Revisiting Tenon Length *LINK*
>Chris et al
Many thanks for the input regarding the tenon length. I thought that I would follow it up with details and a picture of my final decision.
To recap, the legs were 40x40mm and the apron was 19mm wide. Hence I planned to make the mortise-and-tenon ¼” wide (following the rule of 1/3 and this being the width of my nearest mortise chisel). That much was pretty standard.
I had planned a mortise depth of ¾” (19mm), which I thought adequate since the “hall table” was not going to carry much weight and the apron depth of 3” (75mm) should provide more than enough glue area. Your comment of “5 times width” set me thinking.
In the end I compromised on a 1” (25mm) long tenon, each mitred and set ¼” from the outside edge. Picture below.
In the second post I will say a bit more about the project.
