Garrett - 8-Siding or Octagon Marking Gage
Bob Smalser, Seabeck, WA
>All the descriptions I’ve ever read on these needed a good picture, so I thought since I made another one recently, I’d take a pic.
These mark square or rectangular stock into 8 sides, dividing each face of the stock into three equal sections…the first step in planing a cylinder from a square. The nice feature of this design is that it accommodates tapered stock, so is perfect for spars and the oars I am making here.
Cut a block the diameter of the largest cross section of your finished spar or loom…draw a circle in it so the circle intersects the edges. Then use a 45 degree square to make an octagon of it…keeping outside of your pencil lines.
Another block an inch wide and a couple inches longer than the first block is laid atop…both the edges of the circle and the corners of the octagon are transferred to the second block, holes drilled for nails and pencil…and you have your gage.
Offset the holes for the guide nails to insure they are outboard of the circle.
Then merely keep the guide nails in contact with the edges of your stock, and you can mark any tapered piece into an octagon for planing. In traditional construction, spars and looms are thought to look best if the faces of the octagon have a ratio of 5-7-5 instead of 1-1-1, and many go to a lot of trouble making gages that mark those offset lines. My approach is simpler…I mark a perfect octagon and then plane either outside or inside of my marked lines to get the look I want:
To bring your octagon into a round, simply plane your 8-sides into 16 sides. This is easily done by eye without any additional marking. Then once you have 16 sides, you can use any spoke shave, block plane or smoothing plane to whittle those 16 sides into round followed by sanding.
…or you can use use a spar plane (see my article - http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=smalser&file=articles_446.shtml -on making them – it’s easy) to go from 8 sides to round in one pass…
The beauty of spar planes is that with a sharp blade and straight grain, sanding isn’t required at all.
And these 8-siding gages don’t have to be crude like mine:
Boatbuilder Jon Etheredge sent me a pic of his shop-made marking gage, a copy of a rare beauty in the Mystic Seaport Museum, which I have filed away to make one rainy winter day.
Re: Garrett - 8-Siding or Octagon Marking Gage
paul womack
It's easier to just "do the math" than all that marking. The lines for the octagon need to be 29.3% of the way across the workpiece.
BugBear
Math? You aren't typical.
>Besides....people can see the solution in the pic.
Warren in Lancaster, PA
>When I make an octagonal post I too do the math and use a marking gauge. The great advantage of Bob's method is that it can be used on all kinds of tapered beams which could not be done with a marking gauge.
Re: ...and it's a lot quicker!
>No measuring needed. No chance for a math mistake. No need to find your reading glasses. Just lay the tool on the piece of wood and strike the lines. Turn 90° and repeat, etc.
Re: misunderstanding
paul womack
I was only suggested using the maths to make the gadget.
I like (and use) the gadget, but drawing circles and octagons is the long way round to get to 29.3 when making it.
old rec.woodoworking thread
BugBear
