A Simple Hot Hide Glue setup
L. Hanson
>I've been doing a project that required I get out my old hot hide glue setup - so while some (if not all) of this is probably old hat to many posters here, I thought I would take the opportunity to post about it here, just in case someone might find the info useful...
A Simple Hot Hide Glue Setup
Hide glue is one of my favorite glues, and one I consider almost perfect for many woodworking joints. It works easy, can fill gaps, leaves a clear line, mixes with sawdust to accept most wood stains and dies - and it doesn't "stain" the wood like yellow glue can. That's where glue-soaked wood won't accept stain and you get those blotchy areas around glue joints if you missed a spot when cleaning up the glue joint. It's also simply the best glue for dovetails and inlay, and is also used with traditional veneering methods.
Speaking of clean up, hide glue cleans up so much easier than *any* other glue - just scrape the excess off when it dries - and for the tools, hot water removed it, or a trip to the dishwasher will take care of it if it's dishwasher safe. It's also a reversible glue, simply by adding heat and/or steam. It's time-tested, being possibly the oldest glue still in use today. It's environmentally friendly - no nasty toxins or chemicals to pollute our precious Earth.
Some use the ready-mixed hide glue off of the shelf - but this glue has a few drawbacks. It uses a "urea" or some such to make the glue more stable at room temperature, and also to extend the glue's shelf life up to something like 6 months... but that includes the time it sits on the shelf, and these products effect the strength of the glue bond as well. In the end, hot hide glue is still the champion woodworker's glue, at least in my humble opinion.
So why isn't it used more? Good question. Perhaps one of the strikes against it is the requirement of a double boiler, which isn't cheap. Another is the fear of it going bad - hide glue has a short shelf life, after all. Well, I'm going to try and address both of those requirements to see if I can help out the cause of hot hide glue for the masses.
An Inexpensive Double Boiler.
I'll admit I don't use hide glue every day... I usually only do a project or two a year with it. Buying a full fledged double boiler has always seemed a bit too expensive for my tastes... and I usually don't need all that much glue at a time. A cheap and simple solution is to pick up a Rival "Hot Pot Express", available through Amazon or Sears, as well as Rival's own web site at the time of this writing for $12.99 plus shipping. Next, a standard meat thermometer that can be used to measure water temps in the pot, a small tapered jar (mine is a kid's Welch's jelly jar) that can be used to hold the glue, and a shop-made lid to hold the whole rigmarole in place:
Fill the boiler with water, and heat it to about 145-150 degrees. That's not so hot you can't touch it, but hot enough to melt the glue. To prepare the hide glue, mix equal parts of water and hide glue granules into the jelly jar, and place the jar into the special made lid, stirring occasionally. I use a double shot glass (shown in the photo above) to measure out the amounts needed - my jelly jar will hold exactly 2 double shots each of hide glue and water:
As the glue heats up, the granule begin to dissolve into the water, into a syrupy texture. Don't overheat the glue, as it will break down (essentially cook) and no longer bond to the substrate. Once the glue has fully dissolved, it's ready to use. Here, you can see the granules are not quite completely dissolved, but are getting very close:
I find using a cheap bristle brush the most effective way of spreading the glue, going directly from the jar in the boiler (which I keep at one end of the workbench) to the work being glued.
It's often recommended that you make no more than a week's worth of glue at a time, and that you refrigerate it after the work day is done. If that's all you need to do, then you can simply take the jar and put it directly in the fridge, and grab it the next morning when you head out to the shop (unless you are lucky enough to have a shop fridge).
Keeping the Glue Longer Than a Week
That's what I generally do for a weekend's worth of work. But I have a bit of an issue - sometimes I need to keep the glue good for longer than a week - sometimes even two or three. The dry granules will keep indefinitely, but once mixed hide glue has a pretty short shelf life as I mentioned above, and there are times that I won't be able to return to the workbench for a couple of weeks. There's a simple solution - freeze it. Freezing hide glue allows you to keep it fresh almost indefinitely. One luthier makes a batch of hide glue and freezes it into ice cube trays, and just pops a cube out as he needs it (see Frank Ford's site, FRETS.com, which is a wonderful repository of knowledge!). Another option is to pick up some squeeze bottles such as these, and transfer the glue to it, then just toss it into the freezer:
I picked a ton of these squeeze bottles up from American Science & Surplus for next to nothing. The beauty of it is, next time you need some glue, you just take the squeeze bottle out of the freezer, and toss it into your double boiler. It give you a handy dispenser, and when you are finished for the day, you can put the bottle back in the fridge for the next days work.
Hide glue will only stand one (maybe two) freeze/thaw cycles before it begins to break down (just like food!) and will not bond as well. But it's a great way to extend the useful life of the glue, letting you keep it without wasting it until the next weekend you have available to work with it.
Hope this was useful information.
Leif
www.norsewoodsmith.com
Re: A Simple Hot Hide Glue setup
Garrett in Victoria
>Very useful and well-presented information. It will soon have its place in the Articles Department as a Handtools selection.
Cheers, Garrett
Editor, WoodCentral Articles and Reviews
Some nice glue brushes. *LINK*
Dan Donaldson
>Joel has some nice glue brushes for hide glue. I have a couple of them and they work well. The price is reasonable, especially since you can clean and reuse them many times
Glue brushes
Re: My setup for small quantities
John in New Mexico
>Sometimes I find it convenient to just mix up a little at a time, like for doing eight mortise/tennons on a table or a couple of drawers. I took a 1 1/2" copper pipe cap and tinned the inside with solder (probably not necessary, but easy enough). For a heat source I use a coffee cup warmer, just a tiny hot plate with a fixed thermistat.
The only drawback is that due to the small volume, the glue can overheat if left un-attended for 20 min or so, as its directly heated with no regulation. But its a cheap & easy way to give hide glue a try, and nice for small projects where you don't want to store glue til the next one.
John
good info
Steve S., Olympia WA
>I've got an old white oak table that belonged to my great-great grandparents, and one of the glue lines on the top has come apart. I've been meaning to repair it for a couple years and I've wanted to give hide glue a try but have been a little intimidated. I don't know why though since worst case scenario the joint fails, you clean it up and try again.
The wife's got a medium sized electric crock pot and a thermometer in the kitchen, I think I'll dig a jar out of the recycle bin and go experiment a bit.
Steve
How do you clean a glue brush?
Adam Cherubini
>How does one clean a glue brush? I use brushes occasionally, but I've never found a way to clean them. I just let them harden in the pot until next time. Love to know any tricks anyone has.
Adam
Re: How do you clean a glue brush?
>I just soak them in water (warm works quicker), and rinse them out after a couple or three hours. Note that I use acid brushes, which are cheap, but the handle rusts after a few iterations of this treatment, so when it does I throw it out or set it aside for epoxy, and get another one.
As an aside, I don't usually bother to clean them after using them with epoxy, since that increases my exposure to acetone, which is pretty toxic, so usually the brush gets tossed firmly attached to the mixing container.
Re: good info
>I find that a candy thermometer works better than a meat thermometer. It is a bit more accurate, and it doesn't take up so much room on top of the hot pot. However, it is quite a bit more fragile than a meat thermometer.
Re: good info
Paul Kierstead
>Yes, I use a candy thermometer as well. In addition, it clips to the side and doesn't rest on the bottom hot bit. In my experience, it is good to let the water warm up for a bit before inserting glue, especially if the glue container sits on the bottom, so that the heat of the heating element doesn't overheat the glue while getting up to temp.
I bought my Hot-Pot at Walmart for about $12. Works remarably well, though I admit the urge for a 'proper' pot is strong sometimes 'just because'.
John in Kerrville TX
>You can clean epoxy with white vinegar. Non toxic and works very well if you clean it before it sets up.
john
Frank House
>Good info., thanks.
You say hide glue dries clear. I have hide glue from a couple of sources in UK, but it is fairly heavily coloured and this shows in finished products sometimes. I know "clear" grades are available in the USA in moderate quantities, and from a European source about 50 KG at a time (last time I looked).
Can anyone point me to a source of "clear" hide glue (other than cooking gelatine) available in the UK in the sort of quantity that I might manage to use most of in my remaining years?
Incidentally, I am aware that a close-fitting joint will show hardly any glue line, but you will be amazed to hear that not all my joints are that good :).
Frank
Neal (San Jose)
>I poked around on ebay - searched "hide glue" and got several returns for small quantities of high quality hide glue for luthiers from a Canadian outfit called Ratcliff-violins. Their ebay handle is Isilds. They have an ebay store and claim to ship worldwide. It might be worth a try.
You might also try Google. I searched for "hide glue" and got 1,790,000 hits. I tried the first two; both U.S. sellers, but you might find a source closer to you in one of the 1,689,998 other hits.
Glue Pots
Charles
>Leif, I use hide glue exclusively and used to have a jury-rigged arrangement with a hot plate and other accoutrement but I've got to tell you a real electric glue pot is worth every nickel you'll pay (around 100 bucks).
I would only be an occassional user of hide glue if I was an occassional woodworker. The pot is a tool that gets used constantly. Beside lighting, it is the only electric tool in my shop.
L. Hanson
>Try Behlen's UK site for 0.56 Kg cans:
behlen.co.uk
It's the same glue I'm currently using, shown in the photos in the previous post, and IME dries quite clear. I'm also sure Tools for Working Wood would ship to the UK, but I can't predict the shipping costs.
Leif
NorseWoodsmith.com
Re: Glue Pots
L. Hanson
>"I've got to tell you a real electric glue pot is worth every nickel you'll pay (around 100 bucks)"
I'm quite sure of it. I've been enamored with using the stuff for long enough that I should make the jump and buy myself a pot - I really have a hard time finding any drawbacks to using it. It just seems whenever I have a $100 laying around, it already has other plans! Maybe I can talk the christmas fairy into it this year...
Leif
NorseWoodsmith.com
Do you have a link to a good pot?
GolfSteve in Calgary
Re: Do you have a link to a good pot?
L. Hanson
>I think the "Hold Heet" brand is the most common - I've seen one that was bought over 40 years ago that still works. I believe it's what's sold at ToolsforWorkingWood.com and TheBestThings.com (though you should check) - get one with a copper liner if you can, as the aluminum liners tend to corrode away over several years from what I've heard.
Leif
NorseWoodsmith.com
Here is one *LINK*
Dan Donaldson
>Joel at Toolsforworkingwood carries them.
Glue pot
Todd Stock
>Another use for the hot pot is heating lacquer. I keep the gun sitting in the pot between coats, so end up with 120 deg F finish, which helps flow-out and blush prevention.
Charles
>Don't put the glue directly in the pot. Use a small jam jar and simply fill the pot with water. The jam jar comes out and can go in the 'fridge a time or two before you need to make fresh glue.
Pot will look as good ten years from now as it did the day you bought it.
Frank House
>Thanks, not a lot of luck last time I tried.
Our experience of ordering from outside Europe has been mixed. We recently had to pay 28 pounds to get our hands on a parcel value less than five sent by our daughter from Japan - unjustified customs charge plus Post Office fee for collecting said charge. Latter not refundable, former not worth the stress of fighting. Written off as just one more item in the cost of having children. Still, I *suppose* there is an upside as well :).
Not the first time something like this has happened.
Frank.
Frank House
>Thanks. A bit pricey, but I'll give it a try.
