Size of abrasive the only factor in edge keenness?
Denis Chénard, Orléans, Ont.
>Take two different honing compounds with the same particle size. Assume both compounds are hard enough to hone an arbitrary piece of steel. Is it possible that one compound can put a keener edge than the other one?
Or, put another way, is grit size the only determining factor for edge keenness?
Concrete example: 0.5 micron green compound vs. 1 micron diamond paste. Which one gives a sharper edge?
Just curious,
DC
