Re: Glues
John in New Mexico
>Hi Larry,
I'm not much of a veneering expert, but I've a bit of experience with several of the readily available glues for it.
My first choice would probably be plastic resin glue, like the brown Weldwood powder. I've used this stuff quite a lot for curved laminations. The main challenge I've had with it is getting the mix just right. Too much water is fatal, the veneer sticks, more or less, but you get a weak bond and the glue is kind of powdery when dry, leading to edges coming apart. Best bet is to mix by weight rather than volume, or to use the largest volume measuring vessel appropriate for the amount of glue you're making. You'd also need the ability to put a lot of pressure on the piece, which can be difficult with large flat pieces. Thick cauls and lots of clamps are needed.
I've used both Tightbond II and III straight from the bottle, applied with one of those cute little foam rollers from HD (as with the plastic resin glue). Again many clamps and cauls are the rule. This route seems to be a bit more irregular to me, as sometimes I get no warping at all (usually on plywood), sometimes I've gotten a truly frightening warp, easily cured (after initial panic) by veneering the oposite side, and once, way back, we had a horrible time with bubbling under the veneer (paper-backed, applied in vacuum bag).
I also once tried the old method of applying an even coat of yellow glue to both surfaces, letting it dry, and then ironing it on. It seemed to me to work well, as long as you diligently chase down and iron out all the bubbles. It's certainly the easiest method. I was using 1/16 cherry veneer over plywood, and had no long term warping problems, but did have a bit of trouble with the veneer shrinking and splitting a bit. Perhaps that is because the panels went un-finished for well over 6 months after installation. Maybe someone else has some insight or extensive experience with this technique.
Lastly, I'd probably try hammer veneering with hide glue. It's the old stand-by, many people swear by it. Easy to fix, though like the plastic resin, there is supposed to be a bit of a learning curve with it. I've certainly grown to prefer hide glue for joint assembly, as I find it's nice and slippery, so tight joints seem to stick less than with yellow glue.
Thats my 2 cents worth, I hope there's something in there that might help you out.
Good luck,
John
