These Really Are Hand Tools!
>And, there's some historical Hand Tool Forum content associated with them.
Here is some recent treen from the Loxahatchee Toolworks.
The mahogany ladle was begun in response to Pam's spoon carving challenge, but it sat around for several months, after I decided I couldn't come close to completing something completely with hand tools in an hour that I would either use myself or offer for sale. I did finish the teak spoon in an evening.
These were made with some hand tools and some power tools, but no mechanics tools. More information about their manufacture, etc., can be found on the Woodcarving Forum. I strongly encourage you to go over there if you want to discuss them further. Before you do, try to answer the puzzle: What's wrong with the ladle?
Re: These Really Are Hand Tools!
Wayne Anderson
>"What's wrong with the ladle?"
It's not right-handed, it's wrong-handed. ;^)
Wayne
Ernie Miller
>Besides it's made for a left handed person? I think it would have somthing to do with the grain direction of the handle and it's possable frailty. They look nice Now I wil have to wonder over to the board for the rest of the story.
Mike Recchione
>It's hard to tell from the pictures, but it looks like the handle is set up ergonomically for a right-handed person, but the pour spout is on the side that would make sense for a left handed person. But it IS hard to tell from the pictures.
>Actually, when I start to make these, the first thing I do is select a piece of wood with curving grain that will make a stronger ladle. It is very difficult to find a hunk of mahogany with the curving grain that is needed, but in this case, I was lucky. I then carefully lay out the pattern on the surfaces to make sure I don't have any short grain where the handle connects to the bowl. The other curves on the surface of the ladle lead your eye away from the internal curve of the grain itself.
Futility
>The idea is to be able to hold the tool with the wrist straight, and the bend bringing the working end closer to the centerline of the body. It accomplishes that.
More than that, how well it fits the fingers, how strong your grip has to be to transfer forces for typical operations (in this case, stirring the pot and dipping and pouring the soup) cannot be determined from the photo, or any number of photos. Whether it works well cannot even be determined from visual inspection of the object itself. The tuning of the shape is tactile. I do most of it at the drum sander, or with a scraper at hand, for removing small uncomfortable spots. When making right handed handles, I have a bit more difficulty figuring out whether the shape is optimum, especially if I am shaping a tool I don't use a lot with my right hand. In either case, however, I hold the tool in whatever hand it is designed for, push and pull and twist it, and then sand off some material. I repeat this process until I can't make any improvements on the comfort. Some shaping is compromise, especially with multipurpose tools. A small change might make one task it performs marginally more comfortable while making another less comfortable. I can't make it handle to fit anyone else's hand, so I make it to fit mine. Sam Maloof does the same with his rockers, and just about everyone thinks they are very comfortable. The most important thing with a handle is to stop removing material before the diameter gets so small that your finger tips meet the ball of your palm, because then your grip begins to weaken very rapidly, leading to very uncomfortable use.
The biggest problem with most of my ladles is that they tend to roll over and play dead when set down on a flat surface. I figure that's a small price to pay.
