Gouges
Gouges
Gouges
Steve S., Olympia WA
>Just curious - browsing ebay I notice there are a lot of old straight gouges that come up for sale from makers like Buck, Swan, Barton, etc. These things seem to be almost as common as regular beveled chisels, which makes me think they were used pretty frequently by the craftsmen of the day. I'm wondering what they used them for - outside of carving (which I don't do) I can think of only a few instances where I wished I had a gouge. Maybe patternmaking? Anybody use these things in their woodworking?
Re: Gouges
Simple
Bob Smalser, Seabeck, WA
>Sure, patternmakers and boatbuilders use them to hog wood, but any time you have to strike a curve, you need a set of gouges to get the radii right.
You'll simply never do as neat a job as quickly using a router or Dremel.
Re: Gouges
thanks...
>In your pic it looks like you're going to make a decorative end cut in a laminated timber. I never thought to strike the outline with a gouge, I'd probably either freehand it or use a set of french curves, or make a pattern if I had a bunch of them to do.
I guess you'd get a sharper edge with less tearout on your cut by defining it with a gouge, but if you're moving tools from jobsite to jobsite it seems like it would be a hassle to tote around a full set of gouges for a somewhat specialized application. These things are pretty common, and often all bashed to hell which leads me to think your average joe carpenter/woodworker was using them all the time.
Steve
Re: Gouges
Re: thanks...
>But, you're going to have fun trying to find a gouge or a set of gouges to fit either a French Curve or your freehand curve. You are better off letting your design fit the tools at hand. Using the carving gouges to both draw the curves and cut them is much more efficient. That is one of the difficulties of gathering a tool set for doing reproduction furniture: to do it right, you need a pretty close copy of all the tools originally used by all the guys whose work you are trying to reproduce, and their smith probably didn't make any of them to a standard English or Swiss pattern. For long sweeping curves, use a spring batten and a bunch of awls (ice picks), like Bob shows, saw it freehand on a bandsaw and smooth it by eye and by touch with a rasp.
The problem most modern amateur furniture makers have nowadays is having been forced into thinking within the rectangular Craftsman and Shaker boxes that are so much easier for the woodworking magazines to develop successful plans and instructions for. They've been rectilinear precision jigged and fixtured to artistic death. It is often pathetic to watch them try to expand their horizons just a little by putting one curved line in their next project, and then waste so much time trying to jig and fixture that curve with engineering precision.
