Sawing veneer questions
GolfSteve in Calgary
>Ok, this is 50/50 handtool/bandsaw work, but I thought I would ask on this side because most of my question has to do with the handtool work, or at least trying to avoid doing any sanding.
I would like to resaw some 10" wide boards into veneer. No problem, I joint a face, then cut a thin slice off (say < 1/8" thick). The result is that one side of the veneer is smooth and the other side is rough. I then rejoint the main board, and continue cutting slices off.
Now I have a bunch of veneer slices smooth on one side and rough on the other. If I want to bookmatch these slices and glue them onto a substrate, on one side of the panel I will glue the veneer with the smooth side down, but on the other side I will have to glue the rough side down, giving a poor and uneven glue surface.
How do you guys go about smoothing the rough side of the veneer? I can't really handplane the veneer before it is glued to the substrate because it has very little strength and is very difficult to hold. I don't want to spend hours sanding (I hate sanding), and I don't have and don't want a wide belt sander.
I guess I could cut the veneer much thicker (say 1/4"), and then plane everything down to < 3/16", but this seems like a waste of wood and is a lot of extra effort.
Any advice?
Now I have a dumb bandsaw question. I have bearing guides (carter type). This is the first time I've used a bandsaw. I set the thrust bearing slightly behind the blade by the thickness of a five dollar bill - since we don't have one dollar bills up here :-). When sawing, should the blade be pushed back onto the thrust bearing, causing the bearing to spin like mad? I guess I expected that the blade would not contact the thrust bearing.
Everything else seemed to go fine. The 10" wide maple cut like a dream into nice even veneer sheets.
