Finishing curly cherry
Wiley Horne--Glendora, CA
>What's the best surface preparation you have found for minimizing blotch when finishing curly cherry? It has a good bit of grain figure, too.
I expect to finish it pretty close to natural. Maybe a little bit of dye, but no pigment stain.
All suggestions appreciated! Wiley
Re: Finishing curly cherry
>Hide it under a sheet of Corian? Sorry, Wiley, I just couldn't resist.
Seriously, I think you are on the right track. If the cherry is prone to blotchiness, raising the grain with a damp rag, very fine sanding, followed by a seal coat of blond shellac, should minimize differential surface absorption of subsequent coats of stain or dye. If you are still having difficulties, something else you might try is burnishing the surface before applying the shellac.
Paul in NJ
>Wiley,
On formal pieces I plane the flat surfaces and even things up with a light touch up with 320 sandpaper. Where I have to sand curved surfaces I will work through the grits finishing with 320 or 400. On these pieces I especially like shellac and will use varnish where I need a more durable finish. On more 'rustic' items I will use pure tung oil with a touch of Japan drier added in.
Paul Dzioba
Cherry's Natural Color Will Take Over
Steve Elliott
>I faced this issue years ago and prepared a half dozen stain and dye samples for the customer. I finished the piece using a pre-stain conditioner and a diluted coat of Watco, which uses asphaltum as the coloring agent.
Several years later I was asked to do a companion piece to match, and was surprised at how the finish on the first piece had changed. It had the warm look of cherry, but I would never have known it had been stained at all.
I still have the set of finish samples, and they all look the same now. I've left them out where they would be exposed to daylight, and the only sample that looks different is the one I keep wrapped up to show people what cherry starts out like.
If I had it to do over, I'd just show a sample of sun-darkened cherry and say that's what the piece will look like in a year or so.
Thanks and followup on varnish
>Thanks all. I will do the burnishing and thin shellac method. This table top is going to need varnish, because of high wear and to protect an inlaid banding.
Can you folks recommend your favorite varnish for hand application.
Thanks in advance, Wiley
Waterlox
Martin from Granbury, TX
