bow saws vs back saws
frank_shic (walnut ck, ca)
>do bow saws work as well as back saws for making tenon cuts? i'm also interested in using them for dovetails as tage frid and i'd LOVE to hear what the experience has been around here.
Re: bow saws vs back saws
Charles
>Yes, but what you must realize is that Frid used a crosscut bowsaw blade that he filed to a rip profile. A lot of people make the mistake in thinking that he used a 5 or so point rip bowsaw blade to cut joinery. He did not.
Dean J in MN
IMO frame/bow saws work far better than the "regular" back saws I see suggested. All things being equal it shouldn't matter how the blade is supported, the error I see is using saws which are too small (too short in length/depth) and fine toothed. I use frame saws for cutting tenons, and depending on the size of that tenon it may be a 5 tpi or a 9 tpi. Faster is better for me on tenons, if you have ever tried to cut a 4 inch tenon with a 12+ tpi 12-14" back saw you know how tedious it can be. That same tenon cut with a 5 tpi framesaw is quick. I have a large back saw, which may be called a proper tenon saw, but at that size back saws are more difficult to control for me. They feel far too heavy and I struggle with that as I sharpen my saws with an agressive rake. The weight makes starting the cut difficult for me.
As for dovetails -- you can cut them with framesaws, but here I see an advantage in the handle angle of a western dovetail saw.
-Dean
Must
Ron in Kokomo
>Or Frid wouldn't have used one.
I have not been willing to invest the time to become competent with one
so I use my dozukis and my IT saws
Ron
12" or 24"?
>thanks for your insights guys - dean, your comments were particularly helpful!
what length are people using? i see several choices on the traditionalwoodworker web site but i figured that the 12" would be the way to go to cut the day-to-day tenon joints (and maybe even dovetails!) while the 24" would be more for resawing. someone correct me if i'm wrong.
Re: 12" or 24"?
Charles
>Frid used a 24 inch regular bowsaw not a bowsaw rigged as a turning saw. FWIW, I've never seen a wide blade being used in a 12" saw but I suppose that would be do-able.
Adam Cherubini
>I dont' care too much for bow saws. But unlike Dean, (moaing) I'm not lucky enough to own a long backsaw like Mister fancy pants (end childish moan), so I use an 18" bowsaw (9pt or so) for tenons. I rarely see 4" wide tenons, but I think my saw is too fine for even 2" tenons. A 4" tenon is almost like a resaw operation.
I have sawn dovetails with this saw once or twice. The teeth were way too coarse for the work I was doing but that's not the saws fault. The frame was in no way advantageous for this operation though.
I have 2, 700mm frame saws with cheap Putsch blades. These blades must be refiled to be useful IMO. I don't care for these saws as much as my western saws. When i began woodworking, I tried japanese saws, frame saws and western saws. I gave each a fair shake and feel as though I am proficient with each. But I like western saws best. Not that you need my permission, but try them all yourself and make up your own mind. I had fun making bow saws.
I can say I use 2 bow saws regularly: I made a 12" turning saw I do scroll work with and I love it. That and the 18" 9 pt rip compliment my western saws nicely (I'm not counting coping/fret saws mind you).
I would caution you about the influence of band saw users like Anthony Guidice. Blade width and tension are meaningless in frame saws. These are issues in band saws (or so I've been told). Also, all three types of saws appear to have their own pluses and minuses. Don't let any snake oil salesman convince you there is one best sort of saw.
I should reread this an edit it but somebody's crying downstairs!
Adam
Re: Definitions?
>Ary you asking about a bowsaw or a frame saw? The bowsaw doesn't have an appropriate geometry for resawing long boards. It does work OK for dovetails and tenons. A framesaw, on the other hand, doesn't have an appropriate geometry for crosscutting long boards, but still can be used for both dovetails and also for tenon cheeks. Both require more practice, IMHO, than a backsaw or a panel saw, or even a dozuki.
In both cases, the wooden frame is "just" a support for the blades. Either type will support a wide variety of blades, in terms of PPI, rake, camber and set, depth of blade, etc., and both are adaptable to cutting on either the push stroke or pull stroke. They can be used, with practice, to cut in just about any direction.
The traditional reasons for developing both probably had a lot to do with the scarcity of metal for blades, and the relative difficulty of working the steel for the blade vs. working the wood for the frame.
There are olther nice things about a bowsaw regarding its flexibility. Simply replacing the beam with one of a different length and retying a knot adapts the saw to a different length blade. I often use mine with a hacksaw blade, for cutting tool steel stock, drill rod, bolts and pipe. A very shallow blade makes it work well as a turning saw, for cutting curves. A deeper blade is useful for cutting in a straight line, as for tenons and dovetails. If you have a bandsaw, or access to old bandsaw blades, you can make several bowsaw blades from one broken bandsaw blade, which might otherwise be junked. And, there are not nearly as many teeth to resharpen, either.
So, I would recommend choosing a bowsaw or a framesaw only if something other than trzdition and flexibility is more imortant to you. Personally, I find late Nineteenth and early Twentieth century Western saws easier to use accurately, Lots of people who have experience with them, find Japanese saws easier and quicker to use.
Re: Definitions?
Charles
>You're right... loose use of terminology....
Re: Definitions?
Charles
>I do use a large ECE saw for ripping. It is not a crosscut blade filed simply rip, but their dedicated ripping blade.
highland hardware here we come!
>thanks for all the advice and insight, gentlemen! i'm going to start with the $40 continental frame saw that highland hardware sells. meanwhile, i'm re-reading the appropriate sections in tage frid's book. here's to tradition!
Re: highland hardware here we come!
Charles
>You'd be better off with an ECE from David Warren Direct.
The ECE frame and hardware are vastly superior and so are the blades.
>thanks for the advice, charles! maybe i'll need to get another bow saw in the near future so that i can have a rip and a crosscut at my ready disposal...
