Why is a frog called a frog?
Erik S. Friis
>I'm currently reading Garrett Hack's Handplane Book and enjoying it, but I'm interested in some of the terms that evolved for handplanes and their parts. Like why was a frog called a frog?
Also curious about the historical names for pitch, common, York, middle, half. York is perhaps obvious in that it may have been commonly used by planers and/or plane makers in the English city of York. But why is 60 deg called "half" and not 45? It seems that there's some rather interesting history behind them. Is there a book that gets deeper into this historical perspective?
Re: Why is a frog called a frog?
Something 'frogged' is braced or supported firmly
David Barnett - Venice, Florida
Re: Something 'frogged' is braced or supported fir
Erik S. Friis
>Thanks David for the quick reply. Now is the word "frogged" independent and hopefully preceedes the development of handplanes? In other words is it used in areas that are totally unrelated to planes? My guess would have been that it had something to do with the physical appearance (esp. when I saw the holes cut into it for the hold down screws), but it seemed like a stretch. Thanks, Erik
Possibly derived from the Portuguese 'froco'...
>when used as 'fastener'. Frogs are found in clothing. Military uniforms are often fastened with frogs. The use of frog to describe a fastener or an object used to hold fast (frogs on rigging, the frog nut on violin bows), is likely very old. Also, the horny triangular section of a horse hoof is called a frog, somewhat similar in shape to a Bailey frog, I suppose.
Perhaps likely for iron planes...
>is the ribbed supporting plate used for track switching. Of course, the chosen term 'frog' is again used in the sense of support, holding fast, etc.
Re: Possibly derived from the Portuguese 'froco'..
Erik S. Friis
>Very interesting David, thank you....I love word histories, esp when related to tools or tool parts. Any thoughts on the names for the pitch angles? Regards, Erik
And Don't Forget the Use of "Frog" in the
Bob Hutchins in central TX
>floral business!
David, you amaze me. Your posts are always very interesting and well-written and display a broad and deep knowledge of many subjects.
BobH
Joel
>AS far as I know the term only relates to metal planes with a moveable blade support. I cannot recall seeing it in any other literature. That is of course this means the term only dates to the 1850 or so. A good question is the earliest appearance of the word in any literature. A trip to the OED is probably in order.
An obvious root might be the a plane has a throat and well with a moveable base you got a frog in your throat.
In this rare instance...
>...the O.E.D. is lacking in examples, pedigree, provenance, and etymology for 'frog' as positioner, fastener, brace, nut, support, fulcrul tensioner, jamb and wedge, my apologies to Dr. Johnson. Of course, I spared the questioner on derivation of 'froco' from an earlier linguistic 'floco', from Lat. 'floccus', referring to wool, fuzz, nap, and tuft, from which the verb 'flock' is derived, such as "to flock the inside of a box". Then there's 'frock', similar to Port. 'froco', which is a sort of shift, which in a shortened version is called by the Scots a 'cutty sark', which has nothing to do with anything beyond my drinking scotch of a distinction far better than the aforementioned as I type.
'Frog' as 'holdfast' is thesaurically supported, however (couldn't resist). Gonna have to spring (hop?) for a breeding pair of those nifty new frogs of yours, Joel.
Don`t know about the other carpenters but...
Bob Hackett
>The wedge shaped roof flashing that keeps water and ice from building up around things such as chimneys has always been called a frog as far as I know.
Mainely,Bob
I Thought It Was a "Cricket"
Re: And Don't Forget the Use of "Frog" in the
>Hey, that's right! I suppose a florist's frog is pretty much the same thing as the kenzan I use in ikebana, although metal spikes would certainly work better for the woody grasses.
As for broad knowledge, I make it all up, which is why my friends hate me.
Re: A SWAG
>cos(60°) = 0.5
That may be a regional variant term
>Out here in California, they're called "crickets," too, just like in Texas - or maybe the Texans learned it from us.
I suppose up there in Maine, the term "cricket" wouldn't mean much, since they may not get a chance to go through their life cycle in the ten minutes of a Maine summer.
Dick Darin
>Just take it out of the plane, set it on the bench and look at it.
Stephen Slyke
>Carpenters and surveyors often measure a slope as 'rise over run' rather than angle. Laying out dovetails is a good woodworking example, as we often refer to 1:8 and 1:6 dovetails but you rarely hear of marking out a dovetail at 82.9 degrees.
If you were laying out a 1:2 (or 1/2) frog on a piece of metal you could draw a line that connected the corner to a point "one inch over and two inches up". This would be an angle of 63 degrees.
-Stephen
I Learned the Term in NC Where I Grew Up
Bob Hutchins in central Texas
LOL
Cricket and Saddle
Jorge Castaneda
>Here in my neck of the woods, a cricket is a crontaption to prevent ice or snow falling into people, like in entry ways, the saddle protects the chimney.
Yes, there are regional variations, even from mid Maine to downeast Maine.
