A55 Smoothing Plane
signing your work....I know we've been through...
Matt- Los Angeles
>hey all,
I was looking in the archives trying to find a thread on how folks sign their work and couldn't find anything. So I'd like to hear some thoughts,
branding irons?
special pen? (are there special pens that don't bleed into the grain? )
carving?
Thanks in advance,
Matt (who currently signs with a crude punch set--unsatisfying)
Re: signing your work....I know we've been through...
tom in tipp
>My wife has recently signed up for a caligraphy class dealing with Copperplate lettering. One of her projects is to make some paper labels for me to glue the underside or otherwise hidden part of the project.
Tom
Bill Grumbine (Kutztown PA)
>Hi Matt
I have one of those "HANDCRAFTED BY" with my name on it, but have not used it in years. In the first place, it looks like something that should be used on pieces with hearts cut out of them, and in the second it doesn't do so well on my turnings.
I use a woodburner, a good one. Good is defined as, it set me back $100. I used to use a cheap one, but the good one is so much faster and easier to control. I write my name and the date, and any other information desired in PENCIL first. Erasing a pencil mark is a whole lot easier than sanding out a burnt groove. Then I trace it over with the burner.
This ain't handtool work, but it is from my most recent piece:
It is not real easy to see in the picture, but even on dark wood it stands out when viewed obliquely, and it won't wear or wash off.
Bill
John Clifford
>Bill could you tell us where you got your wood burner or the brand. I like your method, very permanent, like I intend my projects to be. Thanks, John.
>Hi John
I have a Burnmaster Hawk, which I purchased from www.woodcarverssupply.com. I got the burner and one pen for $99.00 and change about two years ago. It has been a great tool, although with a very specific application. However, if I ever decide to go into woodburning or carving, it will be useful for that as well.
Bill
Do you do that...
Ted Owen, Pittsburgh
>before applying finish (even if finish is only wax)?
Best, Ted
Re: Do you do that...
>Ted, signing with a wood burner after applying any kind of finish falls into the category of very bad idea. It can be done, but the finish - any finish - melts and scorches very quickly, and makes a real mess. DAMHIKT
Bill
Re: signing your work....I know we've been through *LINK*
GolfSteve in Calgary
>Below is a link to an archived thread that has more info...I really like Ellis' inlaid ivory rosebud.
I carve my name and the date using very small gouges (Lee Valley's micro carving tools; the old ones with the tiny cherry handles).
Archived Thread (main message board)
>I've sometimes carved my name and the date, but only on projects of major proportions, since it takes a lot of time to do the carving.
For smaller, less expensive items, I need a method that's quicker and easier. Lately, I've been using a diamond tipped burr in a Dremel with a flex shaft. Small items often only get initials and the last two digits of the year, instead of a full signature, location, month and year and sometimes the major wood species used. Sometimes, I will then trace the marks with a soft lead pencil for better definition. A white pencil will work on dark woods. To make sure the pigment doesn't get worked out of the signature, a wash coat of shellac can be applied. If you try to do either of these methods after finishing, you will find that the finish will gum up carving tools and diamond burrs. So sign the piece before you apply the finish, but when applying the date, make an estimate of the time you expect to spend finishing it.
