First Full Scale Plane Restoration (long)
MarkSmith
>I am a happy camper.
I found a Stanley 135 (Liberty Bell) at an antique store. It was in very, very bad shape. The metal parts were all completely rusted. All the parts were froze together. The sole was horrible. It had grooves worn in it and it was very warped. It would rock back and forth on the diagonal as much as 1/8". I bought it for $6.
I decided to make it a challenge. I've been on the slope for a couple of years now. I knew this was a plane which was considered to be somewhat of a cheap, low quality item. I figured that if I could get it to work, it might mean that I finally, maybe, knew a little bit about the subject.
I removed the rust with a wire wheel (I realize this is not the best, but I'm not set up for electrolysis). I freed up the moving parts with WD40. I sharpened the blade.
But the most important part is that I took off the metal parts and put it upside down on the bench. I clamped 2 pieces of wood to the sides to act as guides. I used a #5 to flatten the sole. Then I glued a 1/4" thick piece of walnut to the bottom. In the new sole, I made sure to keep the mouth narrow, it was much too wide previously.
Then comes the really nice part. It really works great, and makes very nice shavings. Admittedly, it isn't as good as my well tuned #4, but it works pretty darn good. Pictures to follow, if I can figure out how to upload them.
Mark
