Cutting small-ish, short-ish stopped dado's
Paul Kierstead
>So, fairly frequently I end up wanting to make a stopped dado in the bottom of a box or drawer, and typically only one box or drawer. It is a PITA to setup and fire up the router, and I don't really like the tool to start with (though will admit it is nice when you have a lot to do...). Anyway, I figure there must be an efficient way to cut these with hand tools.
A plough plane: with it's typically long skate, isn't going to work too well over these short distances for a stopped dado.
Saw and chisel.... well, no, that is not efficient, I think especially for dado's that are only 1/4" wide often. Side question: What would be the *ideal* kind of saw for this?
Router plane: Well, would seem to be OK, though by most accords this is for cleaning up, so I don't know how controllable it will be and useful for doing the whole cut. I have never tried one, so it is hard to know, but I keep reading it is for cleaning up the bottom of dado's , not cutting them.
I would love input and help. For example, if a router plane is the way to go, what is the 'best' sequence to do this, ensuring a cut that fits well and looks clean on at least one side?
Re: Cutting small-ish, short-ish stopped dado's
How long??
Ron in KOkomo
>That makes a real difference
Most of the time you'd treat is as a mortise
Scribe lines Use wide chisel to deepen line
chisel out some waste.
Back to the wide chisel to deepen the line
chisel some more, When deep enough.. smooth with router plane
Re: How long??
Paul Kierstead
>Typically in the 12"-24" range. Since it is a box or drawer, you will do 4. I can't imagine craftsman did this with a chisel, unless I underestimate how fast they are with a chisel.
Re: How long??
Paul in NJ
>Paul,
In the case of a drawer, you arrange the dovetails so that the tails of the sides cover the groove you made with your plow plane. The back part of the drawer is cut narrower so that the bottom overlaps and fastens with screws or nails. In the case of a box or set of shelves, you can hide the grooves or dado with a molding or face frame.
Paul Dzioba
George Makowski
>Paul, At the chance of being sticky about language here, are you asking about a groove or a dado?
Going with the grain, a groove, in a dovetailed structure two of them have to be stopped or later concealed. you would be surprised how fast you can work a 1/4" groove against one scribed mark for the lengths you are asking about.
I have seen very narrow dadoes in an original Shaker piece (less than 1/4") but can't say how they were made. Typically, the proceedure would be to scribe/incise the edges with a marking knife, establish the stop with drill or chisel, then saw the cheeks with a back saw. Remove the waste with a chisel.
Good cutting,
George in AL
Jim Crammond in Monroe, Mi.
>Paul,
The way I have done it is to lay out the dado using a marking knife to mark the edge of the dado. Next, using a chisel, make a shallow cut on the waste side of the your scribed line for the saw to start in. Then drill a hole the width and depth of your dado at the end. Square it up with a chisel. This provides a place for the saw dust to go. Using a stair saw or backsaw, make the cut to outline the dado. The stair saw is more aggressive so this goes a little quicker. Clean the waste out with a chisel. Because you are going across the grain, this goes very quickly. If necessary clean up the bottom of the dado with a router.
At first this procedure seems a little awkward, but it is like any other skill using hand tools, with a little practice, it goes quickly. I've made dados this way for drawer dividers in a chest that were a little over 3/4" wide, 3/8" deep and 12' long and they probably took about 10-15 minutes each.
Jim
Re: How long??
Ron In Kokomo
>You oughta see St Roy do just that,
PDQ
Paul Kierstead
>Doh!!! I am talking about a groove (with the grain). From some reason, this confuses me even though I have more then enough experience to know better. This is partly why I include the application; so people can guess what I mean since I can rarely write it correctly :)
Plow plane
Jim Reed@Tallahassee
>use a #45 with a 3/16 or 1/4 blade. Or use the 1/8 blade twice. It cuts fast. Plan your project so that you do not have to stop the groove--that makes cutting and fitting much easier. Another option--drawers are a speciality of the Record 043 small plow plane. Yet another reason why you NEED one.
Re: Plow plane
Pam Niedermayer - Austin, TX
>Agree. The Record 044 works well, too, the 043's big brother. They're both great planes.
Pam
Re: Plow plane
Jack Guzman
>All I ever use to do drawer bottom grooves is an 044.It's quick and easy.---Jack
Re: Plow plane
Paul Kierstead
>Many thanks for all the answers! I see a disctinct trend here.... the solution to making stopped grooves's is to not stop them. This makes a lot of sense, really; a more elegant solution. OK, from here on out, the drawers are all the way through. I think this might require some careful dovetail layout to get the front to have the groove fall in the right position yet have the first pin the right size. Mmmm
Now how about small boxes where there is no way to plow through? I guess it is sawing and chiseling? Not that it matters so much; it is usually a "shop" box to hold crap and practice skills at the same time, but it is always nice to hone some new ones and at least try to make the boxes acceptable.
Re: Plow plane
>You'll find references to plowing through and then gluing in a plug. Always seemed kind of cheating to me.
What I do.
Derek Cohen (in Perth Australia)
>Paul
All the ingredients for a successful STOPPED groove are in the above posts. Here is my mix.
To make a stopped groove I use a marking knife, wide chisel (as wide as possible), a router plane (#71 or #271) or a plough plane (Record #043 or #044).
The process is essentially the same as making a dado (where you are going across the grain), but even easier in that the ploughing is going with the grain. The pictures below came from an illustration of cutting a dado, so keep this in mind (there is no "stop").
(1) Mark the groove lines with a sharp marking knife, and don't be afraid to press down as hard as you can. You may needv to clamp a board to act as a fence. This is the hardest part - keeping a straight line.
(2) Mark the stopped end, and either drill this end out to the desired depth, or chisel it so.
(3) Now chisel TOWARDS to line (as in the first picture). This will create a triangle of waste in the centre of the groove.
(4) To remove this waste, use a plough plane or - my preference - a router plane. These can be set for the depth of cut.
One of the problems using a plough plane only is that they work best by starting at the "end" (and finishing at the "start"). This makes it more difficult to control the end of the groove (well it is for me). I find using a router plane like this to be controlled, quick and easy. I have posted something similar before to create hinge mortises. Same principle.
A few alternatives
Warren in Lancaster, PA
>I agree that a good design will avoid the problem of a groove showing at the edge. Here are some alternatives.
1. I've seen old work where the guy unashamedly left a hole at the bottom of the side of the drawer front. It isn't visible from the front and nothing is going to spill out.
2. I've seen grooves for a false bottom (secret compartment) plugged up in the back of a drawer. Candle boxes also sometimes have plugs. A quarter inch square rod a foot or so long will plug a lot of holes. Plug after assembly.
3. For boxes you can dovetail the corners except for the top (or bottom) half inch which is mitred. This mitred portion hides the groove and also allows you put a small molding on the outside edge or the inside edge around the top panel. Try a practice joint- its difficult to get the mitre to close just as the dovetails are seated.
Also look for the Marples 044...
>It's almost identical. I agree it's really easy to get a good result.
Re: What I do.
Paul Kierstead
>Thanks for the very good illustrastion, Derek! As is often the case, it isn't exactly how I pictured it; this is what makes pictures so valuable.
Many thanks to all the other responders as well; valuable advice which will get taken to heart.
