Draw knive accessory?
Dave Thompson - Champaign
>Every once in a while I get the urge to use one of my draw knives that I picked up, however I always end up with the same issue of, how does one use a draw knife with out a shaving horse. Does anyone use a draw knife on this forum with out a shaving horse?
Is this like having a bench plane with out a workbench? How do you hold your stock?
This weekend I was doing a little cleanup of the yard, adding to the wood pile. Some of the wood was pretty dense tight grain and I decided to put it on the lathe. The dogwood, was a nice surprise. Very tight grain, which reminded me of boxwood, except that it was pink. I found some other dead dense wood (unknown species) was attacked by powder post beetles. I'm not keen on peeling off the pp beetle laden bark on my lathe for fear of some of the bugs getting into my wood shop.... Hence the idea of cleaning it up with a draw knife.. I figure if the beetles are in the wood, then they'll get scalped as the gouge runs over them. But the bark peeling off might leave them hole. What do you think?
Re: Draw knive accessory?
Yes....poppets
Dave (Arlington, VA)
>Hi Dave -
Yes. I use my drawknife without a shaving horse (or pony). I've made multiple chisel handles, and a bowsaw using a drawknife (and a spokeshave) and a bench appliance called poppets. Not ideal - but they work - and have served my shop space-deprived situation.
Regards -
Dave
Jim in Burlington Ont.
Bench vise
>I use my bench vise all the time to hold stuff that needs to be shaved. I also know chair makers that use the Gun stock vise that's sold a Woodcraft.
Could you post a pic..NM
A.J. Byrd
Steve Kubien
Re: Draw knive accessory? *LINK*
Steve Kubien
>Hi there,
Have you considered a shaving pony? Horses are so big and tend to get in the way. Perhaps a pony would suit you better? Besides, the kids will love having a pony around!
Ok, I'll shut up now.
Steve Kubien - who has very few kilometres (ok, miles) on his pony so far but does like it
Ajax, Ontario
Shave pony
>If you're concerned about the beetles getting loose in your shop, why not make something you can use outside? There's all kinds of plans for shaving horses, and some of them are pretty basic. As long as it fits your yard decor...
Re: Could you post a pic..NM
Dan Moening in Cooler, Breezy Sacramento
>A poppet is a pair of devices that can sit in a doghole in your bench and a doghole in your vise.
Basically a bench dog that is raised above the level of your bench.
The poppet typically has a "spike" or pin that pinches the stock between the 2 poppets.
Closing the vise secures the stock between the poppets.
IIRC pictures on the net are hard to come by...The Workbench Book shows their use, however.
Dan.
Or a different tool?
Christopher Schwarz
>Dave,
For peeling bark, I've always favored a hatchet or a side ax. When sharp, it will shape wood almost as well as a drawknife. The bonus is that the workholding is a simple as it gets -- another stump.
Chris
Re: Yes....poppets
>Sorry, Dave.
Read your post quickly before and missed the point of your second paragraph. Poppets would not be appropriate for what you are looking for - 'cause you need a bench, and that would mean the little buggers might find their way into your house. My apologies. Besides, since you have a lathe, you already have a better tool for doing many of the things I use my poppets for.
Regards -
Dave
paul womack
>An old technique (illustrated in the Workbench book) is to hold a sash cramp in your bench vice, and hold the work piece end-for-end in the sash cramp. The example in the book was spokeshaving a cabriole leg, but I don't see why it wouldn't work for you.
Hmm. This might be tricky is you've flush fitted your bench vice rear jaw; I don't recommend this idea. It is ideal when jointing plank edges, but reduces versatility.
BugBear
Thanks
>Thanks guys for all of the responses.
In the past, I have used a set up similar to the poppets on my bench. I usually covet a shave horse when using my draw knife, however, I would use it so infrequently, that I can't justify the shop or lawn space for one. I wasn't familiar with a shave pony. That looks pretty tempting.
Regarding the powder post beetle issue in the bark, I don't know why I didn't think to use a hatchet to remove the bark. I could safely do that outside. I peeled back one piece of bark and would guestimate the number of live wood boring creatures between bark and sap wood to be several score for just one short log. Scary stuff.
Thanks for your time, ideas and leads.
