Two more Water stone Questions
Joe in a Cleveland suburb
>Hi. Me again.
Do you keep your water stones in water all the time?
The instruction sheet that came with mine (King brand) I believe says not to. I'm not an everyday woodworker so I don't need them everyday.
Do I need to use that Nagura stone stuff?
If using a 6000 stone, should I also use the Nagura stone for a few final strokes? Maybe I should pick up an 8000 stone for the final passes?
Btw, I am using the sharpening techniques Chris S described in the WoodWorking magazine last year. Seems to be working well on my chisels and irons. Quick and easy. Of course I am still learning though...
Thanks,
Joe
Re: Two more Water stone Questions
I use to...
Scott Burr in foggy Ben Lomond,CA
>Keep my Kings in water, but not anymore. I got tired of having to clean the stuff that grew on them. I just soak mine for 10 min. or so before using them.
The Nagura stone is only used to create a sullry on 6000 grit and up stones before sharpening. It does not make a stone cut at a higher grit.
Before investing in a 8000 grit stone, try stropping your blades. This should give the same (or close to) the 8000 grit stone. I use the green stropping compound on a piece of double tempered masionite.
Good luck with your sharpening.
Alan Hamilton
>Joe,
I don't use my tools everyday, and I certainly don't use my stones everyday, or every week, or... But I too keep all my stones in water. So far I've had no troubles whatever. However, my oldest stones have been continuously wet for only twenty-five years or so. I find that storing my stones in water makes the sharpening routine easier, and saves time. Also, despite what others say, including the manufacturers, I find my polishing stones work quite a bit better when they're saturated; "just a little spritz" doesn't work as well.
As for a Nagura stone, as in the post above, they are used just for creating a slurry on polishing stones: stones of about 4000 grit or more. There's absolutely no reason NOT to use one every time you use a polishing stone; in fact, it's much better if you do use one. On those hard polishing stones it takes forever to create a good slurry by just rubbing some expensive steel back and forth. A Nagura stone does it in a few swipes.
Always the rebel, I see no reason for an 8000 stone. After a certain point there's no rational reason to use a finer stone--except to massage your ego with an iron that's more mirror-like than your neighbor's. I don't believe an edge polished on an 8000 stone cuts any easier, faster or lasts longer than a tool polished on a 6000; and perhaps even a 6000 stone is overkill.
I'm also a big strop guy...hmmmm...that doesn't sound quite right...oh well... A strop will give a tool that extra little polish that's sooooo pretty and impresses POOSs so very much. But it also serves an actual, useful function. A strop will remove that last little microscopic wire edge left by the final stone. And when an edge starts to slow down a bit, a few swipes on a strop can restore the edge to a remarkable degree.
Whoa! What a windbag!
Alan
