anyone see graham blackburn's video?
frank_shic
>i just recently got the graham blackburn video on making raised panel doors and was completely FASCINATED with the idea and safety of crafting them by hand - i'll admit that i'm TERRIFIED of my router when it's spinning such a huge chunk of metal at such high speeds!
that being said, what kind of plane is he using to cut the dados for the rails and stiles? is it a tongue and groove plane or a combination plane? in my continuing quest to acquire all the handplanes that i will ever need in as SHORT of time possible, i need some of your sagacious wisdom!
Re: anyone see graham blackburn's video?
Jack Guzman from Maine
>I'm not sure about what Blackburn used but I use a plow plane to cut the groove for the panel.---Jack
like a stanley 45?
frank_shic
Re: like a stanley 45?
>yes,or a 44,or any woodie plow.(there are more)--Jack
another QUEST begins!
frank_shic
>thanks for your input, jack! one more question for you: how do you get the curved profile that you commonly see on router made rails and stiles? do you have to use a moulding/molding plane to shape it after plowing the dados?
Re: another QUEST begins!
>Yea,I guess you could call it another quest.More like a slippery slope.Molding planes.There are alot of variations.I don't put a profile on my frames,at least I haven't yet. I leave them square. I like simpler frame and panels than what you get with power tools/modern designs. If I was to attempt a profile then I would need a molding plane/planes or a scratch stock.---Jack
would a stanley 48 work?
frank_shic
>i've noticed that the stanley 45's are going for pretty top dollar but the stanley 48's are much more affordable.
Yes, but
Jim Reed @ Tallahassee
>only within limits. It would work pretty well for 3/4" stock where you need a 5/16" groove down the middle. Plow gives you more flexibility on where the groove goes.
Re: would a stanley 48 work?
>Look for an 044 record. They're pretty common on ebay,go for cheap money and easy to use.---Jack
>The #46 is a skewed plough plane; so it should work better than the 45. I still have to try out mine. If you can find a 46 it would be a good plane to have. The #50 is a simpler and lighter plane that works pretty good. Or of course also as Jack suggested, a Record of Craftsman combination plane goes wuite a bit cheaper than the Stanley and is essentially the same thing.
thanks guys!
frank_shic (walnut ck, ca)
>jim, thanks for reminding me about the size of stock constraints on the tongue and groove plane. jack, i appreciate the advice on the record 44's - they're much SHINIER than the stanley's! and moses, i'll probably start watching out for the 46's as well.
slip sliding away...
