Options for flattening water stones
Joe in a Cleveland suburb
>Hi folks.
What are some options for flattening my water stone? I have a stone that is 1000/6000.
Sandpaper on glass okay? What grit? What do you use?
Thank you.
Joe
Re: Options for flattening water stones
Pam Niedermayer - Austin, TX
>Concrete blocks and/or sidewalks are great and cheap, use one of the flat sides. You can also spend hundreds on lapping plates and diamond "stones," which do work, too.
Pam
What make waterstones do you have?
Derek Cohen (in Perth Australia)
Re: What make waterstones do you have?
>As I recall it's a King 1000/6000 stone from The Japan Woodworker Catalog.
Thanks.
Joe
mikew
>I've found at the building centers around here that the concrete blocks are less flat-sided than they once were and can convex the stone's surface if the block isn't relatively flat.
The patio paver type, though, are still really flat and will stand up to use for a long, long time.
But there is a certain convenience to the cast iron flattening plates for ceramic stones. The Shapton one, while not cheap, will last a long time and stores away conveniently.
Mike
mikew
>Hi Joe,
I would use a patio paver on a King (or Norton) water stone. Just make sure it is relatively flat when you purchase the paver. It'll last a long time. Until I got the Shaptons, that is what I used on my King. Doesn't take many strokes.
Mike
>True, the Shapton plate (I've got the "cheap" model) stores away, not sure how easy I'd call it, have to clean it first to get the grit off. Whereas the concrete block, sidewalk, and/or paving stone can sit outside and don't need to be cleaned or stored in a box. :)
Pam
My "Waterstone Board"
>I got the idea about a year ago for this "waterstone board" after watching a video of David Charlesworth's sharpening video. (Ironically, after I posted a picture of it on the UK website, David contacted me for details about it).
Essentially it is just a waterproof, hooked board that has a place clamp the waterstone and the abrasive flattening material, 220 grit drywall screen.
The drywall screen works extremely well with King stones, which is the brand I use (300, 800, 1200, 8000). I do not think that these will work with Shaptons, but they may work with Nortons.
The drywall mesh is to the left of the Board, and it is clamped at one end. The mesh is quite stiff and will lie flat. If necessary, hold the loose end with your free hand. Spritz it with a spray water bottle before use (I find that flattening dry waterstones just causes them to glaze over). Use DCs recommendation of scribbling lines over the stones before you "sand" them on the mesh (you will be rubbing the stones ON TOP of the mesh, just in case this is not obvious). The mesh will contain the water and clay debre. When it is loaded, just lift the free side and swab under to clean. Really easy. When you need to replace the mesh, just unbolt, remove and replace. I find the mesh lasts a LONG time. It is hard to say just how long, but several times that of sandpaper.
There is also a clamp to hold down a waterstone. It adjusts for different sizes. I use one stone at a time, but it is possible to have more clamps should you want to do so. Place the stone in place, spritz with a spray bottle, and you are ready to go!
Overall, this is a clean and easy to store jig. It has freed up our laundry, which makes my wife very happy, and I am no longer sharing sleeping quarters with the Retriever any longer.
Frank D. in Montreal
>I use a diamond plate on my softer stones because it's easy to store. For my harder stones I glue a piece of sandpaper to 1/2"-thick pice of glass, and load the paper with grit (carborundum). It works a lot faster than sandpaper alone and I almost never have to change the sandpaper.
Re: My "Waterstone Board"
Jake, Windsor Ontario
>How did you make your board "Waterproof"? It looks like some kind of laminate, is it as simple as that?
arw01
>When I get my drywall screen wet, the abrasive falls off.
Alan
arw01
>Bought a diasharp course diamond stone first. 3" x 8" and use that, come in handy also for other blades.
Alan
I've have Kings too...
Scott Burr in Ben Lomond CA
>I use a drywall sanding screen (dry, not wet) on any flat surface around, table saw, float glass etc...
>Jake
Yes, it is an off cut from a kitchen counter top.
>Alan
What brand are you using? I have never encountered that (I use Nortons). The drywall screen mesh, by its design, would force the swarf or debris into the holes that make up the mesh. This is one of the big advantages it has over sandpaper or other mediums - it is self-cleaning.
Dan Clermont in Burnaby
>How flat is your board and does it always remain dead flat?
Interesting idea Derek but how flat is the board you are using the drywall screen on?
Very creative and neat idea I must say.
Dan Clermont
>Dan
The surface of the Waterstone Board is very flat (and has remained so since I built it). It was chosen for its flatness. The reason I specified "waterproof" was to prevent any swelling. I check it every-now-and-then just to be sure.
I am in David Charlesworth's camp when it comes to flattening waterstones. I think that you need to do them frequently, and anything that makes this a quick and non-intrusive action is very welcome by me. I would rather be woodworking. Everything is here at your fingertips, and you do it because it is so.
>I miss King stones for that ease of flattening and also found that the slurry which built up on the 8000 left very nice mirror polish which I don't get with my Shapton 8000. Sometimes I want to sell the Shaptons.
I realize the Shapton 8000 is not at the same grit level as the king or Norton 8000 but it is my finishing stone.
Dan Clermont
Thanks for ...
>all the replies.
Looks like I'll give drywall sanding screen and patio pavers a try and decide which works for me. I'll try those two methods since I have both lying around.
Thanks again,
Joe
arw01
>I will have to look at the package next time I am at the store. An ACE hardware chain. They sell it by the 8.5"x11" sheet for like $3.00 each.
Alan
