Lie-Nielsen Hand Plane Advice Needed!
Erik S. Friis, wish I was in Dodge!
>Hi folks,
I don't have any hand planes to speak of (only a ca. 1970's Stanley block plane). I just watched the Rob Cosman DVD on hand-cut dovetails and now I want to try!
Question is: I want to buy a LN block plane -- there are std angle, low angle, adjustable mouth, Rodmaker's groove, .... I have no idea what all these variations do....which one will serve me best for smoothing endgrain, probably mostly used on drawer material, i.e., I think it'll be hard wood.
Now for the second question, my B'day is coming up and I'm talking my wife into getting me a LN bench plane (Woodcraft in OH has the 20% off right now). Now I watched Rob smooth the finished dovetails with a plane. Was should I get to do similar, 4, 4-1/2, ? Angain a lot of variations HAF (I don't know what this is), bronze, iron, corrugation, ..... to many choices for me and I don't know what they do. So please help me pick out a pair of planes.
Thank you very much in advance for your sage advice!
Re: Lie-Nielsen Hand Plane Advice Needed!
Todd Stock
>Think you answered your own question - low angle adj mouth block and a 4-1/2 with high angle frog.
When you need a longer plane for running edges, etc., go for the #7 once your skills are there for sharpening and basic plane usage - the 4-1/2 and the 7 will use the same blades and frogs, so you can switch the frog if required between SA and HA.
Jim in Burlington Ont.
Jim in Burlington Ontario
>While your wallet's open. I prefer the low angle block for that and a sharp chisel. The squew block is what rob recommends. Personally I don't like it for that particular job. Have you given any thought to the 51/2 bench plane with the high angle frog instead of the 41/2? I'd also pickup the 2 David Charleswroth DVD's What are you going to use for sharpening? Norton stones work great. Absolutely don't look and hold the LN bench chisels or those nasty mortice onces. Sorry for all the enthusiasim I'm gearing up for the next woodshow. Just been squirling away a few bucks.
>"Have you given any thought to the 51/2 bench plane with the high angle frog instead of the 41/2?"
No I haven't, I know little to nothing about hand planes, and I don't know if I should get the 4, 4-1/2, 5, 5-1/2. Don't know yet what a frog is. Then there choice of metal, etc????
"What are you going to use for sharpening?"
Well I habe the Tormek system, but my jury is still out since I can't get a square edge on my chisels with it. I was working with Mr. Tormek on trying to troubleshoot the problem, but I never had a chance to follow all the way through. I'm a bit of a perfectionist, but having the edge of the chisel off by over a degree or so (checking with an engineer's square) really bothered me.
"Absolutely don't look and hold the LN bench chisels or those nasty mortice onces."
Why not? What is a mortice once?
>Thanks Todd, what will the HAF do for me that the std angle won't. Also they have another 4-1/2 that features "corrugation" -- what's this? Thanks, Erik
James Watriss
>My guess is he meant to say "those nasty mortise ones." IE, mortise chisels, and I'm relatively sure LN mortise chisels aren't even in the stores yet.
My guess is he meant not to pick up the l-n chisels at all, becuase they have a cetain weight, and balance to them that, well...
But look at them another day. There's actually a reason NOT to get them, and I'll explain it here.
Start with softer chisels. If you don't know how to sharpen yet, start with softer chisels that are easier to sharpen, and easier to dull down. People will go on in here about how they hate sharpening, it takes so much time, and to an extent, they're correct. It can take time, and it can be a hassle, but you really should learn how to sharpen properly. Particularly if you're going to be using Lie Nielsen planes. A plane, in the end, is a big jig meant to hold a sharpened blade, with the intent to put that sharp edge to work smoothing something out. Lie Nielsen planes are fantastic pieces of work, but if you can't get or keep one sharp, they won't do you much good.
Any woodworking tool you buy comes essentially in kit form. Lie-nielsen is closer to being completed, but any good tool you buy has to be tuned up, even if it's just a little bit. And with few exceptions, knowing how to sharpen, and sharpen well, is something you need to know to be able to properly appreciate these tools. Most reviews, and most reviewers, assume a properly tuned blade, if not a properly tuned plane. You'll get better use from a sharp stanley than you will from a dull Lie Nielsen. I personally have some old stanleys with LN replacement blades that are tuned to the point where they match the performance of my LNs. There's more to that than just sharpening, but regardless... given equal blades, the main advantage LN has is that the planes require less tuning out of the box. There's something to be said about the weight of the bronze planes, but at the end of the day, sharp is still the primary consideration for something you're going to be working with.
Start learning to sharpen with chisels. Start with cheap ones you can screw up if you need to. Irwin chisels, for all they can't hold an edge very long, are great for learning the ins and outs of sharpening. Get used to whatever grinder you have, and learn to use it well. Tormeks have a good reputation, but they're also, IMHO, a wee bit more complicated than a grinder has to be sometimes. That's neither here nor there, though. In the end, you have to learn to work with what you have. The grinder is just there to establish a bevel and a hollow grind, and then you have to hone. Have to. Maybe not all the time on chisels, since you can hammer them through whatever, but if you want to learn to sharpen, then you need to hone. Chisels are just a very easy place to learn, and if you manage to grind an irwin chisel to a nub in the process of learning, it's not the end of the world. Consider it tuition paid into the school of learning the hard way. You pay a price for learning just about anything. Sometimes the price is just effort, but usually there's money involved, so better to spend less than more. And as you use a softer chisel, since you'll have to sharpen it repeatedly, you'll get to learn and appreciate what a really sharp edge is, how much it helps, and what it takes to get an edge to be that sharp. When you know that, you're ready to step up to better chisels, so that you can start to focus more on the work than on the blade you're using.
A plane blade is another step up from sharpening a chisel. Getting a chisel to a pristine edge with 8000+ grit waterstones is overkill sometimes for something you're just going to hammer into things. It can be a case of diminishing returns. Plane blades are another matter, though. Those should be as sharp as you can get them. By which I mean, sharper than they'll come from the factory. LN blades come usably sharp. They should be made sharper. And yes, they have to be square.
Take your time, go easy on the gadgets. When it comes to honing there are always a million ideas and gizmos and widgets and whatnot. And there will always be more ideas and widgets coming out. Some of them work, some of them don't. The sharpest blades in day to day usage seem to be largely found in Japan, and they're all flat ground, and they're all hand-sharpened without jigs. You need to have stones, to sharpen your blades.That's the one thing that you indubitably need without question. Everything else is accessories. That's flame bait in here, I know, but even if honing jigs are god's gift for many people, you can still sharpen without them.
If you're using a tormek, you're hollow grinding your blades, and after that, you should be able to accurately hone by hand with a hollow ground bevel. Find a class, find a friend, or a club, or someone you can deal with IN PERSON if you're having a problem on sharpening. It may be possible to learn to do this properly on your own. But it's easier and faster to learn with someone teaching you. And then it's just practice once you know. But you need someone to look at what you're doing, and be able to inspect your blades, and critique your technique, to tell you what sharp really is, and to point out where you are and aren't getting it right.
That's why I recommend starting small with your chisels... don't rocket for the high end stuff just yet. None of it will really help you until you learn to sharpen. They may last longer between sharpenings, but until you manage to get it ingrained into you how to make something really sharp, you're better off taking the time to practice. Don't worry, those dovetail joints aren't going anywhere any time soon. But you'll have a much easier and more enjoyable time cutting them if your chisels are as sharp as you can get them.
James Watriss
>Corrugation means the sole has grooves cut into it, to cut down on friction. It can be a nice option, especially as you get into heavier planes.
alan womack
>I recently took Robs class in Canada on hand cut dovetails. Most excellent man, great instructor, and you will see the difference in tools at the classes.
Buy the low angle ADJUSTABLE mouth block plane in the heaviest metal they sell. A month or two later buy a second blade that you can sharpen at a different angle.
Buy the 4.5 in Bronze for the weight, a heavy smoother is a good thing. The high angle frog also.
Check the blade for being flat when it arrives, sharpen it up and start making shavings. In the class a dozen or more planes were bought, a couple replacement blades and they were all perfect except on replacement blade had a bump in the back. Tough to get out of A2.
Alan
>Do they sell the 4-1/2 w/ a bronze body? The web site is a little confusing, looks as if they are all iron. The #4 planes list a bronze body. There is a 4-1/2 HAF w/ bronze frog.
>Thanks for all the great advice. I have lots of chisels to start with and did buy a few cheaper sets to practice with on the Tormek. I do need to straighten that issue out as well.
Which 4-1/2 configuration do you recommend then? And which block plane?
Steve Schoene
>The 4 1/2 is not the only choice for the basic smooth plane. Historically it was much less popular than the number 4, usually considered the "standard" smooth plane Personally, I find using the smaller number 4 smooth plane 4 or even the number 3 to be much more pleasurable.
The High Angle is a plus for planing hardwood, particularly for figured hardwood, though the steeper blade does require more force to push. If you do lots of work with softwoods the standard angle smooth plane is fine.
Agree
Frank D. in Montreal
>I like my 4 1/2 for planing flat on a board on the bench but when I have to do more complicated jobs like planing dovetails or trimming drawers I use a number 4, which is a lot easier to control and less tiring (tired=sloppy). With a 45 degree frof I can plane end grain and domestic hardwoods, even figured, with few problems. I wouldn't want a bronze #4 because for me that would make it too much like the 4 1/2 in weight.
I different point of view
Adam Cherubini
>Hi,
I think block planes are mission-less planes. Not useless mind you, but lacking any critical mission to justify their existence in a cabinetshop. So I recommend skipping the block plane. If in the future you find yourself desperate for a block plane, I recommend the LV. Its a quality tool and its considerably cheaper than LN.
If you want to buy a fancy plane, and you've got money to burn, a smooth plane is a good fit. I'd choose the shorter, narrower #4. Although this isn't what you wanted, I was really impressed with Clark and Williams (wooden bodied) high angle smoother. That's a nice nice plane with a very tight mouth.
I'm really impressed with the advice above (sorry I forgot who wrote it. Was it James?) that you should start with cheap soft chisels. I surf WC for two reasons:
1) I learn tons of stuff
2) I'd like to think I can save somebody from stepping on the mines I did.
So when folks ask about planes or chisels, I tell them where I ended up. But maybe everybody has to go through that mine field on their own. Maybe you should pay your dues and put off this big expenditure until you've earned it? Most of us started out by restoring and tuning some stanley bailey product. My first plane was a #4. Maybe that's the "right" plane for you. Something under $10. I think there's a really good chance that having restored some junk #4 you will know all the answers to your questions.
Its just a different point of view for the sake of discussion.
Adam
Jim Brown
>Great comments James. Thanks for taking the time to get those thoughts down so clearly.
Re: I different point of view
Patrick Gibbons, Houston, TX
>It really irks me, but I have to agree with Adam. It doesn't irk me that I agree with Adam, it irks me that I had to go through a lot of territory with blind alleys, overgrown bush and lions, tigers and bears before I had the answers you're looking for. It's very easy to look back with 20-20 vision. But it's because you made a choice, good or bad, and learned something in the process. Go study a little more and find out the answers to the basic questions you have, make a choice, buy something and see if it works for you in the long run.
Bob Hackett
>Some of the best advice I ever got was to put off buying any tool that costs over $100 till after I had stuck with something over 12 months.After that you have a better understanding of where you`re headed.
Most old timers in any craft will tell you about all the expensive tools and gadgets they bought when starting out and then left to do nothing more than gather dust.What I could do with that money now!
Mainely,Bob-Who`s Shopsmith and Snap-on toolbox head the list.
It's a matter of opinion
Dean in Burlington
>Hi Erik,
I have to agree with Adam on the block plane. I have the LN 4.5, 5.5, 8, 164, low angle block and low angle rabbeting block plane. The 2 planes that get the least amount of use are the low angle block then the 4.5. What you will find out is that everyone will have a different opionion of their "goto" plane. For Cosman it's his 4.5. For Charlsworth it's his 5.5. For Alan Peters I beleive it was a 7. For me I'm finding out it's my 8. That's the plane I am getting the most use out of right now. I am even using it for trimming wood when edge banding instead of a block...I don't have to push down on the plane, only slide it across. Now I am working on a project consisting of Hard Maple and Jatoba so the mass of the 8 is what I need. So it will also depend on what woods you use.
Welcome to the slope. You have no idea what you are in for. If you want my advice buy the 5.5 with a high angle frog. It's a beauty that can be used as a smoother and and jointer on small typical boards.
BTW...to answer one of your earlier questions....the 4.5 does not come in bronze.
Re: It's a matter of opinion - 5 1/4W
Norman (Ottawa, Ont.)
>If you decide to not go the LN route and go the LV route instead,
further to what Dean is saying, LV has an excellent 5 1/4W plane.
It has a longer sole that the 4 ( 12 in. vs 10 in.), is basically a No. 4 with a longer toe. You can use it as a No. 4 or as a small jack/ jonter for shorter boards. It is considered a mini-jack.
Not quite a No. 5 at 14 inches.
I have one and it has become my "go to" plane..
Just thought I'd add another plane to the mix,
Norman
OK, but
>Adam,
What do you use as a one-handed plane? Using a plane with one hand saves me time because I can hold down the piece with the other hand, or not have to use a shooting board. I also find it hard to plane a vertical surface with both hands on the plane.
Frank
Re: OK, but
>True Frank..
There's a lot to to be said about one-handed planes. I chose the LV Med. Shoulder plane precisely for this reason. I can easily use it with one hand..
I go to the LN Adj. Block plane often for a lot of work, not only
end grain work. Mostly because it is small, accurate, adjustable for fine work and I can hold the work with my other hand. Not really possible with a smoother, unless it's a No. 2 perhaps.
Let's face it, the high end block planes (LN or LV) are really small BU planes, adjustable for most type of work..
If I had to have only two planes, it would be a smoother type plane, the LV 5 1/4W or LN 5 and a high end adj. mouth block plane.
I would stay with the narrower bodied smoothers, they are more versatile.
Norman
James Watriss
>Well, by now you probably have your planes. I'd have recommended a 4 1/2 in either configuration, and a low-angle block plane with an adjustable mouth. (Like it's bigger brothers, you can always get other blades for the low angle, and grind them to other angles... essentially mimicking the performance of the "regular" block plane.
James Watriss
>It's not a big deal. It was late, I was winding down...
And really, the bottom line for me is that sharp tools can make or break a novice woodworker. I'd rather he get past the sharpening issue than that he get so far, and get fed up, having spent so much money.
AND after having convinced his wife to spend so much money. :) Lord knows if those fancy new planes don't pan out she'll probably never agree to let him buy anything cool ever again.
Re: Lie-Nielsen Hand Plane Advice Needed! *LINK*
Clay C in Miami
>I think your first instincts are pretty good - I'd say get the LN block, the low-angle with adjustable mouth (WITHOUT the rodmaker's groove!). This is such a sweet plane.
For the bench plane, I think you'll be pretty tickled with either the LN 4 or the 4.5 - but, a good point is made above about frog and iron interchangeability, so get this one with either the standard or the high angle frog (the frog is the roughly-triangular part immediately below the blade) and as your next LN plane, get one that's the same width as this one, but with the 'other' frog - that way, the frogs and irons will be interchangeable. (As mentioned above, the 4.5 and 7 can share the same frogs and irons, and a 7 would be a logical 'next' plane after these two.)
Because all the bench planes are bevel down, the only way to change the angle of attack is to change the frog (adjusting the mouth does not change the angle in either bevel-up or bevel-down planes), and higher angles give better results in curly or figured wood (with the tradeoff being they are harder to push). If you get a high-angle frog with this first plane, you can effectively 'lower' that angle by planing at an angle - that is, pushing the plane along at 45 degrees to its lengthwise axis narrows the swath of the cut and has the effect of lowering the angle at which the blade encounters the wood.
Just to add another element and make this decision more complex ...
A lot of folks here believe that the larger bevel-up planes are more versatile and give a surface every bit as good as (some say better than) the bench planes like the 4 or 4.5. This would mean substituting the LN 62 (the 'Low Angle Jack Plane') instead of your #4.5. Then, you could adjust the angle with different blades (ground to different angles) instead of different frogs - cheaper, and allows for many possible angles, instead of only the 2 available in bench planes. Read Lyn Mangiamelli's review of these low-angle bevel-up (LABU) types - you might decide that the 62, because of this versatility, is more appropriate for you than the 4.5. See the thread linked below - there's an even more appropriate one somewhere, but I can't find it right now ...
Clay
one LABU plane thread
Joe Rogers, Northern Virginia
>Just checked... the 4 1/2 body is only available in ductle iron. (minor gloat alert) I got mine at the show price:-)JR
>Bob,I usually mirror your experiences...but I wore out my first set of Snap-On boxes that I got in 1974 and am now on my second set.JR
