The slow speed grinder mantra - kinda O.T.
kenc
>O.K. I know this isn't specifically "Hand tool" related, but I am comfortable with the opinions of many on this board so prefer to post here versus the other boards.
I have just finished welding and machining up a copy of the wolverine sharpening setup (my efforts prove what a good value the REAL wolverine is for about 80 bucks!).
My old 6" grinder is looking at me with that "I need to be replaced" look - one side of it is equipped with a light deburring wheel anyway, so I actually only have access to the other side for WW usage - it has a 60 grit white Al-Ox wheel.
I don't really want to spend a lot on a grinder and note that Woodcraft have both a 1725 rpm 8" unit and a two speed 8" unit for about $80 on sale. The low speed has two white wheels - a 60 and 120. The 2 speed has a grey 60 grit and white 120 grit. Of course, neither is a Baldor, but both look fine for light duty use.
My question is does anyone buy into the low speed grinder mantra?
The reasoning is that it's supposedly too easy to blue whatever you're sharpening on a h.s unit. Personally - other than when I'm being clumsy - I've not had a problem with my 3450rpm grinder so I am thinking that the low speed grinder thing is a bit of a sales gimmick.
Anyway , I would appreciate opinions on low speed versus high speed versus two speed. In particular any opinions on the Asian units that Woodcraft sell would be appreciated - again I know that they are budget quality but I don't want to spend $400 for a U.S made one.
Also, I am equipped to machine up any bits and pieces such as spacers, arbor washers or whatever might typically need truing on cheapies.
I have a Makita horizontal wet wheel for plane blades /honing chisels and a Baldor 500 clone for metalworking tooling and a small "homecraft" unit equipped with a felt wheel so I suppose the 8" would be mainly for wood lathe tools and general purpose grinding.
Thanks in advance!
Ken
Re: The slow speed grinder mantra - kinda O.T.
Bob Hackett
>For less than $80 you can get one of those mandrels,arbors,grinding heads,etc(see below under what`s it called)and a used motor and with your metalworking skills cobble up pretty much exactly what you want and still have money left over to buy the diamond and hardware for one of Sir William`s wheel dressers.
That being said,I see no real advantage in a low speed grinder.If you`re going to be ham handed enough to burn at 3000 RPM then you`ll probably burn at 1500 too.I learned how to grind tool bits on a regular 3400 tool room grinder and the fellows that showed me had been grinding high carbon steel on it for years without burning.The key words are skill and patience.
I`d stay away from 2 speed grinders and especially the variable speed models.They tend to go toes up at about half the life of the single speed.
The turning forum has numerous grinding posts in the archives.Best tip on buying a new grinder?Look for an old,well made one at a flea market or garage sale and add attachments.The Baldor I have cost me $20 talked down from $25.
Mainely,Bob
a virtue of slow speed
bill tindall
>I do the first step of sharpening on a grinder. That means I am grinding to establish a fresh edge and therefore grinding to the edge. With the proper wheel, burning is not an issue( see extensive earlier discussion on the topic) BUT control can be when working at the edge. With my wheel and 3600 rpm metal goes away at an breathtaking rate. A grinder that turned much slower would provide me greater control, yet grind to the edge at a satisfactory rate.
For initially shaping tools, for example a new lathe gouge, the 3600 rpm is desirable if coupled to a proper cool grinding wheel.
Physics--not just a good idea--it's the LAW
Jim Reed @ Tallahassee
>The virtues of low speed grinders are HIGHLY overmarketed. Apply the laws of physics to dispell all the vendor claims. Burning is caused by too much pressure, too much time in contact, poor quality wheel, non dressed wheel, operator error, etc. Speed of grinder just does not come into play at a high level of importance.
My last grinder was new from Costco (Wilton 6" for $29). I have ground three wheels down to nubbins and it is still going strong. Use the cheap wheels for rough grinding and buy some good white or pink wheels for your tools. I swear by my Wolverine (use it at least ten hours a week) and do not see how you could build one for the $80. You must have some really good metalworking skills. Good luck with your grinder.
Wheels & Speeds
>Ken, Oneway offers different grinding wheels that are designed for either 1725rpm or 3450rpm grinders. I don't know all the specifics and really don't have time to dig into all the data regarding wheel composition & speeds, etc. so I've decided to trust their judgement.
Bill has chimed in on this thread and he does seem to have studied the subject in depth.
Re: Physics--not just a good idea--it's the LAW
kenc
>Jim,
No, my metalworking skills are average at best, but I am enthusisitic. The only part I had to pay for was the 1" square tube and some 1-1/4" "nested" tubing into which the 1" fits. This stuff is welded on the corner rather than the flats so that the weld doesn't interfere with the sliding fit. Other than that it was scrap or steel that I had on hand so my total cost was quite low. However, I think you mistook my meaning - I was saying that I considwer the wolverine to be an EXCELLEMT value considering the time I took to make one. I shall make the vari-grind attachment next.
Ken
Jay Samuels
>As posted last Friday, I picked up an old 10" water drip slow speed Dunlap grinder on the way to work last week. I haven't put the speed gauge on it yet, but its really slow, probably a little too slow. Here's my take: It's great for gouges and carving tools. The metal comes off nice and slow, no burning and no endless regrinding because you took too much off one side. It's not agressive enough for regrinding chisel bevels or likely plane irons, although I have not tried one. It seems to me like your other equipment probably covers the field already, but we all know you can never have too much equipment.
Love my Tormek
jim reed @ Tallahassee
>It is slooww also. Slow is not bad if you set it up in front of the tv.
