Cope Joint at 45 Degrees.
Richard A.Gillespie, Jr.
>I'm installing crown molding in a family room. There are two inside corners at 45 degrees. I know how to cope a inside corner when it is at approximately 90 degrees. My mind says the procedure is the same only you have to cut the mating piece at greater than 45 degrees. Any comments?
