Chatter Pitting *LINK*
>The write on this LN scrub says that the sole has some "chatter pitting". I thinking that this must of been done during the machining process and not as a reslut of woodworking. Don't see how it could be done woodworking, but found it curious none-the-less. What thinks you? Must be a collectors item as a new one could be had for $145.
Todd O.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=6195223203&ssPageName=STRK:MEWA:IT
Re: Chatter Pitting *LINK*
Re: Chatter Pitting
Paul M. in San Diego
>That there is the rare and wonderful LN 40.5C. Note the corrugations on the sole. And to buck the trends that everyone else used, LN made this one with the corrugations cross-wise. Patent-pendimg. ;-)
Re: Chatter Pitting
Frank D. in Montreal
>Not to mention the extra high-angle blade for figured woods.
Re: Chatter Pitting
Bob Hackett
>The seller meant to say that this plane was used for chater pitting.
Like alot of the other high end WWing toolmakers LN has branched off into the gourmet kitchen utensil craze.This particular tool was developed to pit the new ultra high carb fruit the "chater",a geneticly engineered cross between a cherry and a potatoe(or tater).
It was originally called a "Porry" but the marketers thought it didn`t sound french enough.
The grooves at the rear of the tool are to keep the fruit from slipping and falling on the floor(there is no 3 second rule in gourmet cooking) after the pit has been removed.
Glad I could clear this up for you.
Mainely,Bob-heading back to the short bus while shaking his head.
Re: Chatter Pitting
>Hogwash! You know as well as I do that they bred the pits out of the chaters before they ever put them on the market. But then, again, maybe this is a very rare prototype (which would explain the high price, maybe), and the guys in Warren were betting that the breeding would not be successful, and they would need a tool that had to do more than just remove the eyes.
At one time, there was no three second rule on the Cohansey, either. When Loxahatchee was Chief of Security, with his long legs and long nose, he could fall half way across the kitchen onto any dropped morsel, usually before the second bounce. Blackdawg, after mistakenly snagging a Thai chili in mid-air, is now a lot more cautious, and the three second rule is once again in effect in our kitchen.
