Honey Locust - any good?
Dave Thompson - Champaign IL
>I have more honey locust on my property than I care to. It seems to be one of the few things the deer and beavers leave alone. One of them just happens to be crowding out a black walnut and so is a candidate for culling.
I was just wondering if anyone had any experience with using honey locust in wood working and could relate any characteristics about it. I figure I'll need some platemail gauntlets and a draw knife to safely remove the 4-5" thorns.
Thanks,
Dave
Re: Honey Locust - any good?
Re: Honey Locust *LINKS*
>For info on honeylocust, including its strength, working properties and shrinkage rates, follow this link to the Gleditsia triacanthos
Then, back up one page to the FPL Center for Wood Anatomy Research, Working Properties of North American Hardwoods and select another species or two that you are more familiar with and whose properties you like working with. Comparison of the numbers and descriptive phrases that you find most important can be very enlightening.
Roger Nixon
>Honey locust is a bear to harvest & turn into useful wood. There is a big distinction between the sapwood (almost white) and heartwood (dark brown). Unless you have a large diameter tree, you won't get a lot of heartwood.
The heartwood looks a lot like walnut but it is harder and heavier. I cut down one tree on my property and didn't get a lot of usable wood. Most of it is still drying. I've turned a couple of chisel handles and the wood turns very nicely and polishes up well.
Thanks
>Thanks William and Roger... this is the kind of info I was looking for. A nice walnut about as dense as oak and non-toxic sounds appealing, assuming I get enough heart wood.
I did find some articles today that mentioned the pods are edible, and more nutritious, protein rich and sweeter than acorns! Although if it tastes like the smell my lawn mower kicks up when running over the pods, I think the squirels and deer won't be getting any competition ;-)
McKay Sleight from Utah
>I have turned two mallets from locust. Beautiful wood. I love the mallet. It has good weight and does not seem to dent much even w/heavy hammering.
>I finally got around to cutting down a honeylocust and put it on the lathe. I think I would describe it just like you did as a nice turning wood with a wide sap wood ring, and a nice dark dense heart wood.
Being the first tree that I felled on my own, I started with the smallest and took out a recently deceased 6" diameter tree. The dark heart wood was about 2 1/2" which should make some nice handles for something.
Thanks again Roger.
