Infill shoulder plane blade - advice wanted
>I recently bought this dovetailed shoulder plane. It has no maker's name and, although it appears patterned very closely on a Norris, I doubt very much it is one. Still, it is very nicely made, has a tiny mouth and should become a very nice user - as long as I can get a decent blade for it (the existing one is incorrect - lacks any overhang and does not hold an edge).
What recommendations for blades (who makes shoulder plane blades)? It requires a 9/64" thick by 1-1/4" wide body (so a smidgeon wider than that is needed) by about 8" long (that would provide an overhang beyond the wedge of 1-1/2"). How much overhang is typical for planes like this?
Any idea of a maker?
Re: Infill shoulder plane blade - advice wanted
Joel
>contact Ray Iles in the UK - the old tool store. He probably has or can make a blade for you pretty easily and inexpensively.
THe trick is getting the width correct. (width of plane body + .006"
thickness should be about 1/8" not really critical except it will change the wedge position a little. beveled on all three sides but only to a knife edge on the cutting edge.
>Joel
Thanks for the info. I will contact Ray.
Something you said rang a bell for me ("beveled on all three sides"). This is the way all my shoulder plane blades are configured, including the blade for this particular plane. However, my HNT Gordon 3/4" shoulder plane (brass and Ironwood) is only bevelled at the cutting side. In other words, flat at the sides (although there is that smigeon projection). Any thoughts on why this should be so?
Joel
>it's certainly less expensive to only bevel the cutting edge but I can't think of any specfic reason why all three sides should be beveled except tradition. There might be a reason but I can't think of it now.
Some advice from a blademaker
Jim Reed @ Tallahassee
>I have made many of these for myself and others. Let me know if you need some help.
As for beveling all sides--there is a controversy about how large a shoulder plane blade should be. Some think it should be 1/64" wider than the plane. Some think it should be the exact size of the width. I think that BOTH opinions are correct. The blade should be made oversized and should be beveled BEFORE tempering. When the day comes that it is fitted to a plane, the sides should be carefully ground to match the plane. It is easier to match a beveled side because there is less material to remove. All Stanley #9x shoulder blades are like this and do not work worth a flip until they are fitted to the plane. Just my $.02 worth.
Re: Some advice from a blademaker
Steve knight
>the bevel keeps the back of the iron from rubbing on the wood. the plane will not sit flat with the iron less then flush with the body.
Mike Swindell
>You might find a local source for 0-1 tool steel or contact a local knife maker and have them heat treat it, perhaps a local blacksmith could also help. How about HNT Gordon - have you talked to him ? Just an idea.
Mike
MikeW
>Hi Derek,
The Gordons bevel down, higher angle shoulder planes with a healthy wedge down into the throat that allows removal of the blade at nearly a flat (lengthwise with the plane) angle.
The infill is a bevel up, the throat is small and in order to remove the blade the sides of the blade are angled to allow clearance for removeal--don't need/cannot turn the blade as much as the Gordon.
fwiw, I've seen old British shoulder planes made like the Gordons that have blade sides square. They too have a larger area/wedge allowing the blade to fully turn for removal.
MikeW
MikeW
>Nice plane, btw...MikeW
