Drill chuck spring
Skip in Falls Church
>I just got a MF #5 egg beater drill - but the spring mechanism for the jaws of the chuck is missing. Otherwise it's a nice enough little drill, a lot of the paint/japan is missing and the gears have a little slop - but not much. The rosewood is in pretty good shape although the cap has a fairly tight crack in it.
In any case it's usable as is - but it doesn't look like it would be that hard to come up with a spring to get the jaws of the chuck working the way they should. I also noticed that the chuck from my #2 fits the shaft - but it's a bit bigger. Before I jump in to fixing it I was wondering if anyone else had done a fix for this problem before? (No need to reinvent the wheel if it's not necessary.)
Thanks,
Skip
