Smooth Sanding
bill tindall
>At the suggestion of Lyn we shall discuss this topic under an appropriate new title. (The density of information on this Forum has been high of late.........)
The discussion initiated in the previous posts under "Question for Lyn" involved sanding wood and how to keep the "soft" regions of a surface from cutting away more than "hard" regions. The hard and soft might be due to growth ring orientation or in the case of trees with hard summer wood, variation of hardness within a growth ring, eg some softwoods like fir and yellow pine, or ring porous woods like oak and ash.
I certainly know of the problem. When my ash floors were professionally finished they were over "screened" after sanding/leveling and the porous regions sanded away more than the hard summer wood leaving a lumpy surface. I think this example provides insight on how this problem can occur in sanding a surface as well as how to avoid it. Don't over sand, sand with the right grits and don't remove significant wood by sanding with a deformable substrate.
I only work domestic wood. Historically I have sanded after thickness planing. More of late, if the project is small, I remove the thickness planer burnish with a hand plane and then sand. But lets deal with the first case as that could more likely lead to a lumpy surface. After many years of trial and occasional spectacular failure I decided that I would never master the belt sander and I no longer use it. I never found an electric pad sander that didn't leave swirls so I don't use them either. I prefer hand sanding unless the project is impractically large, house trim, kitchen cabinets and such.
I begin with 100 grit aluminium oxide paper on a C weight (stiff) backing. If the project is large I will use an air driven sander and a hard pad or a hard rubber hand block for a small area. On something very hard, such as some oaks, I might begin with 80 grit. At least 80% of my sanding time will be spent with this first grit. This coarse grit cuts quick and the rigid backing keeps it cutting flat. Sand paper is cheap and I don't continue using it after it stops cutting properly. I believe lumpy surfaces are primarly caused by over sanding, either because grit choice is too small or dull, and soft backing. When all the planer burnish is gone I often then go to 120, lighter weight paper but still a hard substrate. Then on to 180, A weight paper, hard backing. I may switch to a softer pad at this time for a quick last few swipes. For porous wood I stop here. For cherry or maple I will go on to 220, same conditions as for 180.
On the lathe I typically only make furniture parts. I strive for a finish cut that needs no sanding or at most a light sanding with 180/220 to remove burnish.
My furniture finishes are typically something that builds a protective film-conversion varnish, lacquer, etc. My definition of furniture is something that gets used/touched at least once a day and I want a protective film on it to intercept grime and dings. With these finishes there is no need to sand beyond 220. ( I might add that a conversion varnish finish can be shot that can't be distinguished from an oil finish from typical observing distances. ) Artwork(things less used and touched and more to be admired) can better survive with less armor but I have little experience finishing this kind of work.
I don't get lumpy surfaces with this sanding schedule so I can only speculate why someone might get a lumpy surface. I suspect over sanding, either because grit choice is too fine or grits are too dull, coupled with a soft pad could be the primary cause of lumpy surfaces.
