Krenov Style Cabinet
bill tindall
>This is another project that has been "on the list" for some time. Actually what is shown is the "practice"' cabinet made from poplar. Another, from rift cut ash, is underway.
This is the first non-orthogonal cabinet I have ever made and I was not near certain that the first attempt would be successful. The descriptions in Krenov books are a long way from detailed. Plus, there were a multitude of design desisions that did not seem to be easily made with just drawings.
At the suggestion of Wiley Horne I attached sides to top and bottom with mortise and tennons and I agree that this is a superior joint to the dowels used by Krenov. The door is made first and the cabinet fit to the door. This trick ensures a precise fit around the door and this precise fit is essential. When everything is fit to satisfaction the frame is glued up with the door in place to index the frame alignment. It all came together smoothly and nothing rubs.
All this fitting was accomplished with a shoulder plane and bench plane. The curved profiles on the top, bottom and shelves were done with a spoke shave and file. The flat surfaces were planed ( I normally finish sand) for in this situation a planed surface was a clear advantage. I found that a planed surface does not fuzz up when it encountered water during coloration with the water based material(see below)
When I make a practice piece of poplar, if it turns out ok I stain it with synthetic milk paint (Country Colors, I hate milk paint) and overcoat with a thin protective layer of delustered conversion varnish. I find the result a pleasant appearance that fits in somewhere around the farm house.
