Square chisel bevels and coplanarity
Dave (Arlington, VA)
>Hi All -
Maybe it's just a spate of poor chisel selection or maybe I just hadn't noticed in the past, but the last four chisels I picked up in flea markets did not have their tops coplanar with their bottoms.
THOSE OF YOU WHO SHARPEN FREE HAND, COVER YOUR EARS....but for those who use a jig (especially the LV Mk I) on occasion this condition is making it difficult for me to get the cutting edge of my new-to-me chisels perpedicular to the sides of the chisel. While I can (somewhat) easily flatten the backs of the chisels the LV jig (original, not the Mk II) uses the top of the chisel to register relative to abrasive (I'm using scary sharp).
While I do also have an Eclipse knock-off I have had other problems with it: the chisels do not want to sit coplanar to the top of the jig (i.e. they don't want to sit flat in the groves), and for my larger blades (1" and bigger) the tightening process seems to deform the blade and not leave a "square" edge.
Now the chisels are nothing special: a Fulton, a "Sampson" from one of the hardware stores (I can't remember which off the top of my head right now), and a couple of no-names, but has anyone else noticed this problem. Is it just a function of "cheaper"/second tier chisels, a function of the fact that the workmen of old didn't use jigs and therefore didn't care if the top was coplanar to the bottom, or whatever.
Also unless I am mistaken - and while I havent' taken any of these to the grinder (yet) - I think I would face the same problem - since the "top" of the chisel would register against the grinder rest and thus "establish" the angle of the bevel edge relative to the sides of the chisel.
If you've run into this problem, how have you gotten your edges square to the sides of the chisel? Is there a system, or am I stuck with trial and error?
Thanks - and regards -
Dave
