THE WOODRAT IS BACK!
Cambered irons and hollowed stones...
Joe Rogers
>Just thinking about the article in PW by David Charlesworth. He has a very effective method for producing a cambered iron on a plane blade.
In the article there was a side bar about a diamond plate with a non flat(read hollowed) surface. I believe the hollow was linear. This was able to produce a "pre" cambered iron and required just additional refinement to use.
Later I considered that most of the stones found in old kits were hollowed also but in the narrow dimension. I think that this produced a cambered iron because the normal stroke was with the blade at an angle to the stone...not perpendicular to the length. With reversal of the blade from one skew to the complementary angle the camber will be a natural result. Backing off the wire edge could be done on the edge or end of the top surface where the stone remains flat.
I think the old timers didn't have flat stones because they didn't need them. They also were skilled enough to produce a flat back when necessary. Straight honed plane blades...didn't need them or use them.
If Davids article re discovers an old skill, then the need for a flat stone may have evaporated. At least with regards to the materials in use at the time.
Any other thoughts on this? Adam C... could this be a good hypothosis?JR
Re: Cambered irons and hollowed stones...
Sounds reasonable to me...
Dave (Arlington, VA)
>Hi Joe -
Creative thinking and an interesting observation! I'll be looking forward to seeing what others say.
Regards -
Dave
Steve Kubien
So what you're saying is....
Steve Kubien
>...that I may no longer have need of the 3/4" thick slabs of glass I recently acquired (very gloatable price---free) for my sandpaper sharpening methods and I can go to water or oil stones without free of wrecking them?
I too will be following this thread. Nice bit of reasoning.
Steve Kubien
Ajax, Ontario
Re: So what you're saying is....
Joe Rogers, Northern Virginia
>Quite possibly.
I have mostly natural(Arkansas)oilstones in my arsenal. I also have a well dished Crystolon(sp) stone inherited from my dad. He was an artist and wood carver. He was able to get razor edges on his chisels. With this well worn carborundum. I don't know if this thought is true or not about cambered blades but I was just thinkin...specially since this pre hollowed diamond plate has appeared. I'm kinda hoping great thinkers here can poke holes in my theory . If I'm right it might set a bad example. :-)JR
Not so fast
Adam Cherubini
>Just from a practical standpoint, I think we're still stuck with flat stones for backs at least. I must admit that a fair amount of my sharpening time is restoration- maybe just because it takes so long.
Re: Not so fast
>Depending on the extent of the back that was flattened in days of yore coudn't they just use the end of the stone where it isn't dished? How much of the blade backs were worked then? If it was just a 1/4" or a 1/2" it seems workable to me.JR
Toshio Odate
Frank D. in Montreal
>If I'm not mistaken it was Toshio Odate had the diamond plate developed. He also wrote several years ago about Japanese Shokunin using a *very slightly* dished stone to get a camber. It all depends on just how much camber you want and whether you can trsut your stone to keep that camber (I guess oil stones keep their shape a lot longer). I've been using camber to my advantage since I read Odate. I start with the blades I want straight, then toward the end of my sharpening session I do the blades that I want a slight curve to. I use water stones though so I still have to flatten them often, and I don't want a real big curve on most of my blades anyways. If you look at the concave diamond plate we're talking thousandths. Using a totally dished stone might also add more difficulty to sharpening than it would help. The curve would have to be pretty even, and along the width; curve along the length would round over the edge it seems to me.
Just a few thoughts,
Frank
Adam Cherubini
>Joe,
The hollow stones we find may be the result of hacks or knife sharpeners. We mustn't assume this is the way these stones always were. But I think you're right.
Actually, a skewed blade on a dished stone will naturally camber. No need to reverse the skew angle. The leading edge gets dubbed on the push or pull.
Or on another stone? Or stropped off?
I don't see alot of flat backs on old tools. Again, we can't know if this was the result of abuse or not. Some tools, like molding plane irons, seem less flat than others.
I disagree. They certainly did need them. But the point is moot because by holding the blade perpendicular to the stone, you can achieve a straight edge.
I'm not sure if I mentioned this before, but I'm very interested in this subject and have given it some thought. I feel as though the pieces of the puzzle are here, but I just can't see the image. Forgive me, I've had a tough week, but sometimes I feel like our Grandfathers are trying to tell me/us something. I am in no way convinced that we have a better system of edge tool making or sharpening. It all just seems so complicated. They must have had sharp tools to do what they did, yet their sharpening media was junk by modern standards.
So I think you're on to something, Joe. I promised Jeremy that if he came to Pennsbury, we would practice free hand sharpening with period stones and period chisels. I'm sticking with that. Pretty sure you have to keep the steel and the stones in sync- no A2 or CPM with these materials/methods.
Otherwise, I'm doing what you all are doing- i.e. sharpening on glass with as high tech stuff as I can get. But the voices tell me there's an easier way. Of course the voices also tell me to dress up as a clown and murder people, so there's that.
Adam
>Clown suits. Now there is something I can help with. My mother used to be in the circus.True!JR
Warren in Lancaster, PA
>I do two things to avoid hollowing the stones. First I use a separate set of stones for small chisels, carving tools, and turning tools-those more likely to wear a hollow. Second for all tools I try to use the whole stone and go over the edges. Even so the stones eventually become too hollow for plane irons.
It is true that the fact that I use cambered irons means I can tolerate a slight hollow in the stone, but I think a newly flattened stone gives the most control and best results. If the stone is higher at the ends than the middle, it is harder to keep a consistant bevel. If the stone is flat from side to side it is easier to conrol the amount of curvature on the edge. It is always a joy to use a stone that was just flattened.
Todd Hughes
>I guess I was lucky because when I started out slow head me never knew that my sharpening stones had to be perfectly flat to get a sharp edge. Not knowing any better I just use my old stones that have a slight dip in them like you see and I get edges sharp enough to shave with pretty easly. I sharpen the blades in a sort of figure 8 pattern or go from one corner to the other diagonaly if with a wide blade and can't see how a slight dip would affect anything...the blade just rides over the dip.Actually with use the stone should tend to wear pretty flat though truthfully I never fool to even check to see....not important to me. Maybe if the stone had say a 1/2 in. dip it might affect something but I never felt the need to worry about just a slight dip.....Todd
Clown Suits
Steve Elliott
>There's something I can speak of from experience. Here's the proof:
I've outgrown that one, but some days I think I should still be wearing one.
Joel
>If you were correct then when Arkansas stones came on the market (c. 1850) people would not have rushed to buy them and driven other sharpening stones out of the market because the advantage of a dish stone would be lost.
But they did rush to Arkansas stones.
they also had no simple way of flattening arkansas stones. but since it takes years for a good one to dish they didn't have to worry so much. Most of the dished old stones I have seen have been clearly not in a cabinet shop any time recently - actually I would say 99 percent of the old stones we see at flea markets were never used for cabinetmaking in the first place. Razor and pen knive sharpening by mostly amatures. IIRC the old stones I have seen found in provenounced toolboxes that we never abandoned to be used randomly were pretty flat.
maybe no as flat as what you get with hours of worrying about it but certainly flat enough.
I think once you have the technique of sharpening down you worry less about whether something is flat or not. You can eaisly tell when you sharpen if the system is working right - and if it's not you can compensate.
Say that again Joel
I didn't understand this sentence. I looked for provenounced in the dictionary but it wasn't there.
Todd O.
Re: Say that again Joel
>Provenance is an unbroken history of ownership of the antique item, in this case the toolbox and its complete, catalogued contents. Joel means that we know from this history that the tools in the box were always used by skilled craftsmen to the original intent of the tool, or that they have laid unused since laid down by the original craftsman. More importantly, it means we know the stones weren't ever used for sharpening bulldozer bucket teeth, or smashing bugs or driving nails, or to prop up a washing machine foot, other random abuses.
Greg B
>Just curious about the source of the reference to hollowed stones. I haven't seen the PW article, but using a hollowed stone, in either direction, doesn't sound like something David would recommend. Maybe it's more of an editor's aside/guess, but maybe not.
David's methods, both learned from others and developed on his own, seem to be the result of a certain kind of evolution. The aim is a combination of precision and repeatability. This explains the use of honing guides, for example. He also routinely warns against the waterstones getting out of flat. With a flat stone, you know exactly where you are and can apply point pressure where you want to, on the way to your desired result. You dictate to the iron, rather than the stone doing so. An out-of-flat stone introduces an extra variable to the equation and would, I suspect, complicate matters for the sharpener. (not to mention the question of creating the right hollow shape, both in width and length, stone-to-stone) This sounds counter-Charlesworth to me.
I wonder if our forebears simply were skilled enough and practiced enough to make a stone work despite it being out-of-flat. In other words, making due with a sub-optimal stone rather than throwing it away. I wonder what they would have done with water stones and a quick method of returning them to flat once they became a little dished. In that case, would the old stones we find still be as hollowed as these oilstones?
Dan Clermont
>I will sometimes use a hollowed stone to my advantage and sharpen a cambered blade with it before reflattening it.
I think that we have all become used to the easy to flatten Japanese stones compared to the arkansas stones which require more effort.
We also tend to use planes manufactured to higher tolerances and try to create air tight joints whereas our forefathers were more concerned about making enough furniture to feed the family.
Dan Clermont
paul womack
>In "the Village Carpenter" by Walter Rose
http://www.wendoverbookshop.co.uk/rural/rose.village.htm
http://nika.frontier.iarc.uaf.edu/~cswingle/archive/get.phtml?message_id=58354#message
He says:
It is easier to sharpen a true edge on a wide tool with a narrow stone than with a wide one".
He argues this because it's difficult to keep a wide stone flat across it's width. This appears to imply that a straight edge is desired, and a flat stone to create it is desirable, but difficult to attain.
BugBear
paul womack
You got that right. Have you seen the stones from the Mary Rose?
BugBear
Man, I knew those Cohansey bugs were bad,
mike recchione
>but I didn't realize they could dish oilstones!
"More importantly, it means we know the stones weren't ever used for sharpening bulldozer bucket teeth, or smashing bugs or driving nails, or to prop up a washing machine foot, other random abuses.
philosophical question
mike recchione
> "The aim is a combination of precision and repeatability."
While this is probably David Charlesworth's aim, I wonder if it is anything like the way people worked back when. The analogy I think of is piano playing. Before the days of keyboards and sound modules, you pretty much had to play whatever piano you found wherever your gig happened to be. Even if you didn't play in bars and honky-tonks, where the instruments might be severely out of tune, have broken keys, etc., you had to deal with variations in things like touch, registration, tuning - and still produce music good enough to get paid for. Repeatability was an issue, but the approach wasn't to insist that all pianos be identical.
The key to quality and repeatability was sensitivity to feedback. You do something, feel the effects, change the something to bring the effects closer to what you want. An iterative process. And I guess the more skilled the musician/craftsman, the faster the iteration converged.
I'm certainly not a "master cabinetmaker", but I can sharpen pretty well. My stones are mostly old and ideosynchratic, and I sharpen on them freehand. The key, as someone said here recently, is to pay attention to the effects of each stroke on the stone, and to adjust what you do to bring them to a desired result.
Do my plane irons come out exactly the same to the nearest micron every time? Of course not. Is it necessary? Again, of course not. Just like the pre-keyboard piano player, you adjust your touch to the way the plane or chisel is behaving now , and that's what makes your results repeatable.
An opinion, anyway.
Steve Kubien
Re: Clown Suits
Steve Kubien
>I was lucky to be born 6 years before Star Wars hit the theatres. That meant a lot of time dressed up as Darth Vader (and he's still the coolest bad-guy I know of).
Steve Kubien - jedi in training
That's just not right
Adam Cherubini
Patrick Gibbons, Houston
>I think our forebears flattened stones just as we would. That's how they dealt with out-of-flat stones.
Clarification
Adam Cherubini
>Walter Rose probably used the word true when he meant straight. So when he talks about a true edge, he means a straight edge. The question here is how did they make curved edges and did they used dished stones to achieve them? The follow on question is what can we learn or do differently?
I don't know what stones Joel is talking about. Seaton chest? Have these been examined with this in mind? I need more data before I draw conclusions.
Adam
