Boiling Oil (Stones) *PICS*
L. Hanson
>Not too long ago, a fellow woodworker (see Oil Stones Article on my web site) was telling me about his success washing an old clogged oil stone in the dishwasher. In the old text he quoted was the way the "old timers" did it - by boiling the stone on some rags. Well, LOML wasn't about to let me try the dishwasher method, so I decided to give the boiling method a shot. I bought an old oilstone of unknown type for a few bucks (the box it was in looked well made, so I figured somebody thought it was worth something once upon a time), and threw it in an old pan on top of some rags and and boiled it with a little dish soap(for about 15 min. or so):
You can see the oil coming out and darkening the water around the stone. The rags are to keep the stone off of the hot bottom of the pan, and keep the resulting temperature differences from cracking the stone. If you're wondering about smell - the whole time I was boiling it I was reminded of being in my grandmothers' kitchen - the smell was the same, and pleasant - at least to my mind. She used an oil stone in the kitchen... LOML didn't complain either, so it didn't bother her, either.
I then let the thing cool on the stove before I removed it so it wouldn't crack then, either. The results were quite good! After boiling the oil out, I put some 60 (then 100) grit sandpaper on the jointer bed and sanded the stone flat. Here's the progress shots:
You can see the marked improvement. Prior to cleaning, this stone was clogged about to the point of uselessness. Now - I needed to test it out. I found an old throwaway chisel:
Nothing spectacular about this old thing. Next was to sharpen it. First - the stone seemed pretty fine, so I ground a new bevel on it, then tried it out on my new 'old' stone, then stropped it on leather charged with honing compound - here's the progress shots for each of those steps:
The edge in the center is straight off of the stone (hollow ground, so not in the center, just the ends of the bevel!). There's a satin sheen to it, not too much more coarse than my translucent arkansas stone gives (if any), so I'm pretty confident this is a hard arkansas stone.
To try it out after stropping it, I took an old piece of ash and gave the end grain a go (and try as I might, I couldn't get a good shot of it - sorry!):
Cuts through the end grain cleanly and easily. So - for about $10, I now have a great stone!
Just thought it might interest some to see what my results were.
Leif
