Stripped screw in LA block plane
Sandor in Boyds, MD
>I have a Stanley 65 with a stripped levercap screw. The threads in the casting have been sheared off. (You cant see that on eBay....)
Has anyone had success repairing this type of problem? I can't use a helicoil because the Stanley thread is an odd pitch (as in oddball)
Short of making an insert and pressing it in from the sole, I was thinking JB Weld. Has anyone used this stuff to repair damaged threads, and if so has it worked? I'm thinking of using the screw with wax on it to make the threads in the JBWeld.
Also I need a throat adjusting cam lever for this same plane, the one that mounts under the front knob. Anyone have a spare?
Thanks in advance,
Sandor
Re: Stripped screw in LA block plane
Bob Fawcett
>I don't think JB Weld or anything similar would have sufficient strength.
I think you will have to use an insert like a helicoil. If this means you must substitute a different screw, that may be you only choice.
Jim in Burlington Ont.
Jim in Burlington Ontario
>Loctite has Form a thread product. We use it on high pressure water pumps all the time. Industrial supply house would carry it.
I have used pc7 putty with great success.
Ed Snow
>It is incredible stuff. I used it several years ago to modifty the trigger on my autococker paintball marker. Still there no wear noticable. Since it worked so well for that I used it to repair the broken depth adjustment block on a $.50 60 1/2 works well.
Wandering OT
>Would this product work for a 1" screw? I've got a vise with a very odd thread configuration for which I can't get a replacement nut easily. Would it work to use this product inside some 1" pipe?
Wandering OT
>How large a thread size does this work? Would this product work for a 1" screw? I've got a vise with a very odd thread configuration for which I can't get a replacement nut easily. Would it work to use this product inside some 1" pipe?
Re: Wandering OT
>The only thing it really doesn't like oil and grease. So you'd have to soak the vise up pretty clean. I've used it on High pressure water pumps alot up to 150HP pumps so it withstands alot of vibration. Often the tread's have been rusted up and there's no option of rethreading.
Is silver soldier an option ?
Ian in Sydney
>Clean the hole, add a few drops of silver soldier and retap the thread. The heat from the small amount of silver soldier shouldn't be enough to deform the sole.
Of course this assumes you have / can get the right sized tap.
Did you mean solder or soldier? (NM)
James Watriss
Todd Hughes
>I think you will have a hard job making new threads so that you can screw the screw in and out with any product. Instead i would approach the problim from the angle of permanatly gluing the screw into the plane at the correct depth for you to work the lever cap.If you think about it once the screw is in the right position why do you have to screw it in or out any way? I think JB weld would work for this....Todd
Yup, Loctite
Doug Littlejohn
>product works well. Saved my bacon on a couple of occasions. As you have little to use, go ahead and give it a try. I bought mine at an auto store as well.
Sherwood
