REAL MILK PAINT
advice on old wooden planes?
James Watriss
>I know a bunch of you have worked, probably extensively, with some of the older wooden planes. Thanks to ebay, I have a few on the way, including a huge 29" jointer... yeesh! I have a general idea how to make them work, and I do own a copy of astragal press' book "How to make wooden handplanes," so I have written reference material if I need it, but I wanted to post in here to read what regular folks had to say about wooden planes, why they use them, what to watch out for, etc, etc...
Is there anything I should do to/for them when they arrive? (I'm assuming I'll have to sharpen them, but other than that...?)
Care and feeding?
Warning signs of impending doom and disaster?
Any practices I should avoid like the plague?
Re: advice on old wooden planes?
Hi James
Larry Williams
>First, let the planes acclimate to your shop before you do anything to them. Don't, as in NEVER, soak them in linseed oil.
When they're ready to work on, bed the irons before you do anything else. Pay particular attention to the fit of the wedge. If the wedges don't secure the iron properly with only a tap from a mallet, you won't be able to properly adjust them.
Most people who have problems setting wooden planes are setting the wedge way too tight. They'll drive it down with heavy blows. They never stop to think they'd have trouble adjusting metal planes as well if the tightened the lever cap screw to a few hundred foot pounds.
I do have a little information on Sorby but not enough to post about. Just some dates of operation before they were bought out by Marples who continued using the name.
Richard A. Gillespie, Jr.
>James,
I understand the use and adjustment of metal body planes much better then wooden ones. The theory with western style wooden planes is once you have the sole flat and the mouth with the proper size/spacing to the blade you adjust the blade with hammer blows.
Here's where things go to h*** in a hand basket with me. I set the plane with the blade loose on the work bench and then tap the wedge tight. This usually drives the blade too deep. I then have to hammer the back end of the plane to back off on the blade. This sometimes loosens the wedge and I have to start all over again. Just when I start getting fluff off the blade I hit it too hard with the hammer and the blade is too deep again. The hammer I'm using is a small iron ball peen hammer weighing about 10 oz.s.
As you can tell, I understand the theory but haven't been able to get the systems to work well yet. Don't get me wrong, I'm going to keep trying. I've got a number of wood planes in my collection and I don't like them just collecting dust.
R.J.Whelan
>James,
You can't get much better advice than from Larry Williams.
You may find that if the plane was used hard the leading and trailing edge of the throat are dinged up. The trailing edge (behind the iron) isn't a big deal (as long as the iron is well supported) but the leading edge is important. I have found that in inlayed patch is the simplest fix for a banged up edge or too-large throat opening - hate to admit this but I make a pattern out of 1/4" plywood and use a router with collar to excavate the sole for a patch and then use the same pattern with a smaller collar to cut the patch out of an appropriate material. I make the patch a bit oversized and let it hang into the throat and then file the extra material to the same bevel as the remaining area of the throat. I patch the throat before flattening the sole - I flatten the sole with a #7 set very fine, or with the handy 8" j***ter followed by a light lap with 600 paper on a granite plate.
Good luck with your woodies - I think you'll find, as I have, that they're a pleasure to use and a lot less tiring to use during a long day in the shop.
- rj -
Dan Donaldson
>I think that part of the problem might be in Larry's post. If the wedge is not fitted correctly, they are a bear to adjust. I have several wood planes and it almost never takes more than one or two taps to set it. I usually set it so that the iron is just about even with the sole (no cut) and lightly tap the wedge. Many times, this is all that it takes and the plane is ready to use. If not, then I tap the iron just a bit, then reset the wedge with another tap. This will usually do it. If I do get it too deep, then a tap on the back (or on the front strike button on my long plane) will retract the iron, a tap on the wedge and it is usually ready to go. If the wedge is fitted properly, it should not take much to set it. I use a small hammer that I made out of pink ivory for adjusting mine. I don't know what it weighs, but it is probably around 3-4 ounces.
On most of the planes, I could almost set the wedge with hand pressure alone.
Adam Cherubini
>When setting an iron you set the blade flush (no cut). Then tap once on the iron and once on the wedge and try the plane. No good? repeat the two taps bing bang. Try it. Repeat.
If the blade gets too deep, don't tap the heel. The heel releases the wedge. Tap the toe. Then tap the wedge.
I use a small wooden carver's mallet. bing bang bing bang That's how it goes. Light taps.
Adam
Pam Niedermayer - Austin, TX
>You can always cheat a bit and use a hardwood blade setting block, which is nothing more than a block of wood under the mouth. The blade will dig in usually just enough to hit the good cutting depth.
Pam
Adam Cherubini
Yeah. Yank the irons. If they are rusty, submerge them in kerosene while you wait for the bodies to acclimate. I'd wait a month or more depending on where the planes came from. At very least check the clearance between the cheeks and the iron. If the iron fits beautifully now and the body shrinks, the cheeks will crack. Should be some slop in there.
Make sure you hone your irons correctly and be careful not to overheat them. Cast steel plane irons may have 300F tempers. Easy to achieve.
Otherwise, I wouldn't rush into fixing beds, flattening soles, or patching mouths just yet. Its amazing what can be done with a really bad plane that has a sharp iron.
Adam
Hi Larry.
James Watriss
>Thank you Larry, I really appreciate your advice.
I also wanted to thank you again for coming to North Bennet back in May. It was an amazing workshop, and I plan on trying to make a few more planes over the summer. It's what got me interested in wooden planes, so in part, I blame you for this. :)
Any advice on getting planes acclimated to the weather patterns here in Boston? Monday it was 88 degrees with 90% humidity. Tuesday was the same. Wednesday it rained, and since then it's been in the 60s, with lower humidity. Next week promises to get hot again... do planes really acclimate to that sort of thing? How long should I expect for them to acclimate?
Many thanks to everyone else for posting so far... I've been taking notes, and as soon as the planes get here I'll be sure to take my time getting them ready.
