How to build an air conditioner *LINK*
Jeremy Osner
>Way off-topic but here's an article I thought a lot of you folks might enjoy: a student at U. Waterloo describes how he beat the heat on low budget.
Home-brew a/c
Re: How to build an air conditioner *LINK*
Dale Lenz
Re: Interesting idea....
Dale Lenz
>thank Jeremy for posting.. Wondering about, using a cheap small volume water pump to put the "waster water" back into the tank. At that point all you need to do is to keep on adding ice. Keep on thinking here.... and find something with an insulated tank. I'm glad I've got me shop A/C, but then again, it ain't free. The closest I came to reinventing the wheel was to place a damp towel in back of my fan, Evaporated type blower, increasing humidity in OK during the summer ain't good.
It has always amazed me what the human brain can come up with when needed, : ' >
Thanks again,
Dale
Re: The advantage of a basement shop
Jeremy Osner
>My shop is the coolest spot in my house -- when it gets really steamy out I go down there to cool off.
Todd Hughes
>I bought an air conditioner a few years ago from a girlfriend ,[more to help her out then anything] but never got around to bringing it home and putting it in the window.Normaly once things start to get hot I get to thinking about putting it in but by the time I get around to maybe actually doing it is getting close to fall and I figure no reason to put it in now....Oh well guess I just never seen a real need for one....Todd
Victor Parisian
>I just sent this link to my son (an Aggie Engineer) who spent his college days (5 years) in Law Hall - one of the last non airconditioned dorms at Texas A&M. The dorm has been torn down since then and replaced with a parking garage. The son has survived with a great sense of humor about it.
Isn't this the same thing as a swamp cooler?
David W. Dougherty
Re: Isn't this the same thing as a swamp cooler?
Alan Hamilton
>David,
It's not the same.
A "swamp cooler" draws the hot air through a mesh (usually some kind of very thick, but extremly porous material. I've seen them made of a kind of straw) that is kept wet--as wet as possible.
The hot air passing through the wet pad evaporates the water--which takes energy of course--so the heat energy of the air is "spent" evaporating the water. That's why the more proper name for this kind of air conditioner is "evaporative" coolers.
I'm sure that's clear as mud. Maybe one of the engineer-types around here will clear it up.
Alan
Guess the 'dedhorse' Ain't in Texas, huh?!
Bob Hutchins in central TX
>Not an engineer type, but I will point out that anyone who has ever spritzed him/herself with a spray water bottle or even just splashed water on the face or bod on a hot day is using the same principle. It takes energy to move water from liquid to vapor, and the energy can be taken from your overheated skin.
That's nothing new
HC Sakman
>Couple of years ago I've seen some Australian made box fans with built in water circulation (water falls like a curtain behind the fan). It wasn't as effective as an air conditioner, but it was close enough as far as "coolness" of the air they were blowing. Very cheap to operate but it wasn't very cheap itself. (Approx. $300+ Cdn. and you can buy a small real a/c that cools one room for less than $300!)
Chico...
>A swamp cooler doesn't work very efficiently if you're already in a swamp, or on the Eastern shore of the Chesapeake (Dead Horse Forge, for example) or on the Eastern shore of the Delaware (Loxahatchee Toolworks, for example), or in any other maritime climate. Hereabouts, when the temperature is high, so is the humidity, so there isn't much use in trying to cool the air by evaporating water before it gets to you. It's a lot more efficient to just turn on the fan and let the moving air evaporate sweat. If you sit under a shade tree, the tree will do all the evaporative cooling for you.
I guess some people think there are some advantages to living a long, long way from the ocean, including low humidity and a dearth of hurricanes and nor'easters, but I like it green, and I prefer that the temperature seldom goes above the mid 90's. Sometimes, however, the carnivorous bugs can be brutal.
Re: Guess the 'dedhorse' Ain't in Texas, huh?!
Pam Niedermayer - Austin, TX
>With the humidity on the eastern shore, it's probably effectively much more oppressive than in central TX. Always was in VA. The only saving grace on the shore was the sea breezes.
Pam
>Hi Pam!
Must be because I've been workin' outdoors in the heat for the last coupla weeks. Seems to be gettin' hotter earlier than it did last year. How easy I am to spoil!
Are you still in Austin? IIRC you mentioned something several months back about a move back East.
BobH
>Yes, it's been high 90's for the last couple of weeks here in Austin. I was planning to head to Michigan, but haven't yet, decided to take some classes here. I'm only doing physical stuff in the morning and night.
Pam
Perth in summer ...
>.....tends to get to 40 degrees Celsius or 104 degrees Fahrenheit most days. This lasts from November/December as late as March/April.
It is not unusual to get 42 degree C (or 107.6 degree F) days.
Fortuneately it is a dry heat and remarkably bearable. Still, we live with aircon in homes. I would hate to be without it. It is that and the "Fremantle Doctor", the strong afternoon seabreeze, that cools us down.
Regards from Perth (on a 17C or 62.6F wintery day)
Todd Hughes
>Gets plenty hot here. This past week actual temp. got into the 90's with the humidity the heat index was well into the 100's.Come summer will be even worse. I'm lucky that I live right on the water [Chesapeake Bay] in the woods which helps alot in keeping me cool....and of course I guess all of that cast iron might act like a heat sink too!....Todd
Re: Perth in summer ...
Ernie Miller
>Derek A young lady who does volinter work in my office is heading your way in Feburary for a ten month walkabout and a year of collage studdies Any tips or info that would make her time ther more enjoyable would be apreciated.
And that is a swamp cooler...
Luke Herzberg
>which requires the humidity to be low enough to evaporate water, consuming energy, cooling the air. This garbage can cooler simply uses the energy input required at his freezer to make the ice and uses the water to transfer it.
He maybe could do a study for one of his college classes on why his power bill is higher from running his freezer and a fan than it would be with an air conditioner.
...but, yeah, it is pretty clever though (and cool!).
- Luke
Further dour middle-aged thoughts
>I found myself wondering about all that water. The picture seems to show it just going to a drain. At least the drain line could be run onto a lawn.
The whole thing reminds me of the next step up from the automatic door closer my freshman year roommate made from pulleys, cord, and a Coke (tm) bottle filled, as I recall, with water. With half the effort and less money, he could just have installed a screen door spring on the door.
Wendell @ Murphy, TX
>What year was your son? I am Class '91.
Gig 'em Aggies!!!
Wendell
>Hi Ernie
Where about will she be travelling? Oz is a BIG place. (It is a 5 hour flight or 3 - 4 day drive between Perth and Sydney).
February in Western Australia is Hot. Not a cloud to be seen for a few months yet. Amazing, endless white sand beaches with clear turquoise warm water. You could drive from the southern tip to the far north in 5 or 6 days. I have heard some compare it to California. Lots of desert in the north and forrests and vineyards to the south. A windsurfing mecca in the summer and surfing in the winter.
Sorry, didn't mean for this to become a travelogue. I have lived in this area for about 18 years and still get carried away.
Let me know where she plans to go, and I will be more specific.
Victor Parisian
>Dan was class of '94 (95?). A lot of spirit in Aggieland. As a Michigan State grad I was impressed. Did you ever experiance Viking Night at Sabessa(Spelling?) Dinning Hall?
>I lived off-campus so I didn't get the pleasure of eating at the dining halls very often. I probably missed out on a lot of on-campus activities but that probably kept me out of trouble too :)
Wendell
swamp cooler...
Victor Parisian
>After hearing about them for years from friends who had lived in El Paso, I finally saw my first swamp cooler in operation several years ago out in the little town of Comfort, Texas I knew immediately what it was. It looked like a large box with louvers on all sides sitting on top of this small home. Since I was heading west at the time, I started noticing more and more of them in towns like Junction, Odessa, Ft Stockton and Van Horn.
Last time I was out that way there were still a few visable I suspect most have been replaced with regular A/C.
Victor - sweltering in 97 degree Houston
>Yeah, trees are good. I've got a couple of adult red oaks that make it more comfortable living without ac, probably 10° cooler than the surrounds. Unfortunately, the work shop is in full sun all day long. Got to grow some more trees, testing paulownia right now.
Pam
