My Bugbear bowsaw
Frank D. in Montreal
>2 years after starting I finally finished my Bugbear bowsaw. It's made out of cherry and maple. The handles are boxwood, from Lee Valley. I finished it with shellac and wax.
My Bugbear bowsaw
Oh yeah,
>The only electrons I burned were with a drill press, to make the holes for the blade holders.
Re: My Bugbear bowsaw
>Very nice, Frank. How does it cut? I've never used one but am going to make one.....some day ;>)!
Shellac is such a nice finish. How did you make the string & what is the winder made of?
>Thanks Frank,
I just tried it out on some maple and it works like a charm, very well balanced. It's a huge step up from my coping saw. The only slight problem is that there isn't enough friction between the handle and the frame so the handle turns a little as I saw. I should be able to fix this with a leather washer between the handle and frame.
The string is waxed hemp twine from Lee Valley. It works even beter than I thought because with the wax the knots stay tight when the string is loose. The paddle is made of the same cherry as the two "arms" (vertical pieces) but I made it a few days ago so it hasn't had time to darken yet.
>Frank
That's beaut!
Definitely one for Bugbear's Hall of Fame (he places pics of them on his website). Sadly, mine (posted here about a week ago) did not make it there - Bugbear explained that it did not look like his, so I explained that it did on the inside. He did not buy this. I guess that I will have to try again. Yours is an inspiration.
Great work.
Very nice Frank...
Scott Burr in Ben Lomond CA
>It looks great. What did you use for the blade?
Thanks for sharing.
Re: Very nice Frank...
>Thanks Scott,
I used a 10 TPI 1/4" bandsaw blade. It's easy to break with a couple of long-nosed pliers, and I just torched the ends to drill the holes. I have a 6 TPI 1/2" blade for heavier ripping.
Thanks Frank
Norman (Metcalfe, Ont.)
>I like it Frank..
I should make myself one of those..
Norman
