Re: LN 60 1/2 Rabbet Block Plane question
William Claspy in Cleveland
>It's a nice plane. I like mine and use it occasionally for tenon cheek sizing and rebate tweaking.
That said, you may be asking too much of it. It would not function particularly well at trimming tenon shoulders. The blade pitch is correct, but the size and ergonomics of the plane are not suited to that application. And it is fine to use as a plain old low angle block plane, but keep in mind that the blade advance is not as fully functional as other low angle block planes. Nor does it have an adjustable mouth. It also has a very tight mouth, which is great for taking thin shavings across grain (say on a tenon cheek) but not necessarily so good in use as a regular old block plane.
Other methods you can use for sizing tenons to width are 1. sawing more accurately to begin with (I'm still working on that one...) 2. file 3. wide chisel
Trimming tenon shoulders is more difficult with anything but a shoulder plane. Doable, but difficult. And the 60-1/2 R won't really help you much there.
My two cents.
Bill
