A GREAT Day in the Shop - Long
Glenn
>WARNING TO POWER TOOL USERS: DO NOT READ FURTHER OR YOUR PLANNER AND JOINTER MAY NEVER FORGIVE YOU.
What a great day I had in the shop yesterday. The only thing I accomplished was to flatten one board by hand with my planes. I had watched Rob Cosmans� � Rough to Ready� video; so I went into the shop motivated and inventoried all my hand tools and decided to give it a try. The results were a so-so flat, square, and super smooth piece of wood.
I have an older Stanley scrub plane that I got from my grandfather that had been sitting on a shelf for a while. (I think it had been sitting in his garage before he gave it to me for a few years untouched). So I flattened the blade, an easy task compared to my A2 blades, flattened the sole, I figured this was not necessary but I was pumped up, sharpened the blade and scrubbed my first piece of rough lumber. All I can say is WOW!!! I cannot explain it but using a scrub plane has to be one of the more fun and pleasing things to do in the woodworking world. After a minute of using that scrub plane all I could hear was a solid �CRUNCH� when ever I moved my feet. And for all the wood I was removing it was surprisingly easy to push the plane through the wood. I then continued in the loose order that Rob had outlined with my jointer plane. I put a pair of winding sticks, two � 18� or so pieces of wood I pulled out of the scrape pile and checked with a straight edge, on the wood and low an behold no wind, another WOW. I scribed an edge from my reference face so the board would be ��, I was tempted to go to a �� so I could use the scrub plane more, and continued. I finished by squared one edge to the reference edge, a pretty simple task. I checked the final thickness with a dial caliper and the thickness varied from .743� to .760 after measuring in six places, I know this needs to improve but I didn�t care because I was in woodworking bliss.
I finished the evening up by sweeping up the thick and whispy shavings and unplugging my jointer and planner before I went in the house I cannot wait to get back in the shop this afternoon.
Re: A GREAT Day in the Shop - Long
Dean J in MN
>Glenn --
Fun isn't it?
I'd say you while you are unplugging your jointer/planner you can unplug the part of your brain that deems it necessary to "thickness" and/or 4 square your wood. Most of the time you don't need to! So that saves you a lot of work... You face joint one side, and then edge joint one edge. For a lot of parts you are done. Think of a table apron. Once face jointed, who cares how thick the board is, or of the inside is still rough? You only need that one reference face/edge to build a table. You rip it to width and call it done. In fact, I'd say you start with a board as long as all 4 aprons (plus tenons), face joint one side, and joint one edge. Rip to width, then crosscut the aprons out. You just eliminated the need to "match" all the widths of your aprons. So in a table my reference faces are the outside of the aprons, no need to work the insides.
Building a case piece? Then I use push the reference face to the inside, the outside of the case only needs to be smooth, not perfectly parallel to the inside. Mark your case dovetails from the inside. If you are doing blind case dovetails you spend a little more time making the ends where you cut the tails parallel, but the entire side need not be perfect. Divider dados are referenced from the inside, drawer runners, &c.
This is part of the mindset that you need to grab a hold of, or will grab a hold of you as you work with hand tools. The tools have a lot to tell you if you listen. I'm just starting to see the very tip of that iceberg. :)
You can leave the 4 square wood behind you with the power cords. Of course there are times it does matter, but save your energy for those tasks.
Welcome to a great place!
Dean
Scrubs are fun huh...
Scott Burr in Ben Lomond CA
>Glad to hear you had fun. I love my scrub planes. Dean brought up some good points about minimun planing requirements, something I'm just starting to learn. Congrats Glen!
BTW What's a power planer? ;^)
Power planers
>Scott,
You've heard of power walking? Power planing is like that - you pick up a piece of hard wood (Douglas fir for the plebeian, oak for the upper middle class, jarrah for those people who think lattes are just too lower class for words) and plane until you've sweated off at least five pounds.
scrub iron
--cc--
>Sounds great - I've ordered a new scrub iron from rarebear, and am gonna try to build on this summer (unless LV's new one comes out and breaks my will).
Since this was the 'first time' for both you and the plane, how did you sharpen the radiused bevel?
Clay
grinding radiused bevel
Andrew F in Australia
>Hi Clay,
I pin the centre of the radius onto the tool rest with a left forefinger and then rotate the entire blade around to get the grind.
Works for me.
Cheers,
Andrew
Radiused irons
Bob Hackett
>Ask one of your turner buddies if he uses a Wolverine grinding jig or just visit the turning board archives to see what one looks like.
Fab up a jig to use with the pocket and sliding arm(the best one I saw was an old metal drawer slide with a square nut brazed(or epoxied)onto it to allow a thumbscrew to lock it).It should have a point on one end(to fit in the pocket) and a means to clamp the iron on the other.
You now have a jig that is capable of grinding any radius out to the total length of that jig and sliding arm combination.
BTW-that same sliding arm(minus the jig) can be used to grind the bevels on those old framing chisels with the rounded face that you`ve been struggling with.Just scribe a line on the back and grind to it after placing the chisel handle in the pocket and adjusting the arm to get the proper bevel angle.
The Wolverine is a very versatile set-up and handy for alot more than just turning tools.
Mainely,Bob
