Flattening Shapton Pros *LINK*
Matt Malin
>Would it be ok to flatten Shaptons with the flattening stone below? I just don't want to shell out the $128+ to get the lapping plate if I can use what I already have.
100 Grit Ceramic Flattening Stone
Matt Malin
Re: Flattening Shapton Pros *LINK*
Tim of Livermore
>This is what I've had good success with....other than with a 1K hippo. It flattens the 1K hippo but I still have *glazing* type problems with that stone.
I wish it also came in a extra coarse/220 grit since I kinda think that might help with the 1K stone. The coarse/325 grit Dia Sharp flattens my 1K hippo but the stone still stops cutting after only a few passes. I have this "glazing" problem only with O1 and A2 steel cutters. My japanese laminated cutters are abraded very rapidly.... :confused:
For reference, I've used the Dia Sharp for only a little bit now. I like it for flattening/renewing 5K and 12K hippo's and an 8K pro. I also have the coarse Duo sharp. The dia sharp, IMO is better for flattening. It is steel backed and so weighs a lot more. It is also less money ($50) and so far performs as well as the duo.
Have you been following the woodnet thread?
alan womack
>As long as you have a way to flatten the flattening stone. I got a pair of ice bears for $2.00 each, then had to buy a diamond plate to flatten those!
SO now I just flatten with the diasharp course.
100 SIC couldn't hold up for more than a few seconds to the flattening stone.
Alan
DON'T DO IT
Neal White (San Jose)
>I bought one, but it isn't flat. It does more harm than good.
Re: DON'T DO IT
Fred Krow
>The ceramic flattening stone is not flat.
I checked several at the local Woodcraft store with a straight edge, not even close to flat.
Regards,
Fred Krow
Matt in Boone Iowa
>I picked up the Shapton flattening plate and grits at the Woodsmith. They had a really good price on them. Thanks for the input.
Re: DON'T DO IT
Steve Knight
plus it is tricky to keep flat and tends to clog up.
Re: DON'T DO IT
Jack Guzman from Maine
>I bought a concrete patio block(8"x16"x2")and flattened mine.It works fine now.---Jack
Re: DON'T DO IT
Rusty Miller-Tye, Tx
>Jack,
I've heard of people using concrete blocks but never tried it. What do you need to do to prep the block? Anything. Do you just use it the way it comes.
Rusty
Re: DON'T DO IT
>I used water on the block,but it was flat enough ,as bought, for the task.---Jack
